Tool Talk Discussion Forum
Need help wit Borg Warner hydraulic pump?
unioncreek
10-04-2007 12:01:47
A friend game me a Borg Warner hydraulic pump that come off of a farm truck hoist. I want to put it on my Farmall M to add live hydraulics for my loader. It has a number on it, but I can't find that exact number anywhere on internet. I found one that looks just like it and it says it has a CCW rotation. Is that rotation as your looking at the shaft end or not? Here's the number if anyone needs it S15S10A1122L.
Thanks,
Bobg
Rod (NH)
10-04-2007 13:28:07
 Re: Need help wit Borg Warner hydraulic pump? in reply to unioncreek, 10-04-2007 12:01:47
Hi Bobg,
I am assuming the pump is a gear pump. See if the pump has two different size openings. If so, the larger opening will be the inlet. Looking into the inlet opening you should be able to see portions of the two gears and see the point where the gear teeth mesh together. The correct shaft rotation is that which makes the gear teeth at that mesh point appear to move TOWARD you while looking in the inlet opening. If the two openings are the same size, perhaps one of them is marked in some way as the inlet. This is general and should be applicable to all gear pumps.
third party image Rod
