Tool Talk Discussion Forum
Western snow plow pump problem
Rayy
10-03-2007 13:26:18
I tried to lift my old plow on my farm truck today and it wont lift. It will move side to side. Any ideas what to check. The fluid is full. It has been sitting in side my barn all year. Older Western pump. (control cable type, pump runs when I try to lift it)
Thanks,
Ray..
bradk
10-03-2007 18:59:02
 Re: Western snow plow pump problem in reply to Rayy, 10-03-2007 13:26:18
Like Dan Mn said; it's out of adjustment.It's always the same problem with the older cable sys.because the cables are constantly stretching. ~brad
Matt L
10-03-2007 14:50:56
I had a simular problem with mine - turned out to be the wasnt enought power to trip the silinoid.
Dan Mn
10-03-2007 14:04:50
Your lift cble is out of adjustment. Lose it were it goes into cyl in or out
Rayy
10-03-2007 14:56:16
 Re: Western snow plow pump problem in reply to Dan Mn, 10-03-2007 14:04:50
The pump turns on when I engage the cable. It will turn the blade left and right but will not raise the blade. I took the cover off the side of the pump and tried moving the lever by hand and it just turns the pump on but nothing else. It has leaked some fluid out over storage and I added some and still nothing.
