Tool Talk Discussion Forum
6 volt batttery
PK Caldwell
10-03-2007 11:27:03
6 Volt on 53 Ford Jubille was hooked up backwards or negative to ground. Gauges are stuck and Generator appears not to be charging. She does start when properly connected with charged battery. Seem to remember a reverse pollarization technique. What is it and have i done any damage? Thank you .
soundguy
10-04-2007 10:25:28
 Re: 6 volt batttery in reply to PK Caldwell, 10-03-2007 11:27:03
The NAA is a B circuit charge system.. NOT LIKE the 8n.
Polarize by touching BAT lug to FLD lug.
Soundguy
kidbob
10-04-2007 10:05:50
Take a jumper wire and momentarily touch the BAT lug and the ARM or GEN lug. This will polarize the generator.
soundguy
10-04-2007 10:27:14
 Re: 6 volt batttery in reply to kidbob, 10-04-2007 10:05:50
the 8n used an A-circuit charge system.. you did indeed polarize BATt to ARM/GEN.
The NAA used a B-circuit charge system.. you polarize BAT to FLD.
Soundguy
suptscottyb
10-04-2007 05:10:49
There was a discussion that covered this within a few pages back ...
Bob - MI
10-03-2007 12:47:41
You may want to post on the 8N site. Lots of Jubilee guys over there.
