Tool Talk Discussion Forum
Sissor Lifts
T_Bone
10-03-2007 04:49:47
I just bought a 19ft sissor lift with a trailer last night for $2000. 4ftx7ft working platform. Makes using ladders and scalfolding a problem of the past.
The trailer tandum axles will work on ruff terrian where the small tires of the lift would get stuck easy.
I just thought for the cost what a labor saving idea.
T_Bone
S. Crum
10-03-2007 21:25:02
 Re: Sissor Lifts in reply to T_Bone, 10-03-2007 04:49:47
I found a 25' 'snorkel' or boom lift to be a lot more fun than a sissor lift. Especially with new tires and batteries. Paid $1,500 for it, put the siding and soffet on the plasma building and resold it for $2,000 2 weeks later.
buickanddeere
10-03-2007 20:50:35
New hydraulic hoses.
Billy NY
10-03-2007 06:37:02
They are a labor saver, and quite the time saver, but when on uneven or soft groud they get stuck like a boat anchor if you've got one with the hard wheels. Also remember to let the platform down when moving, some can be a little jerk at the controls, once you get used to it, most of that goes away with little finess at the joystick. Have to be careful when using plywood under them, needs to be secured, sometimes on uneven ground the drive wheels can shift the plywood. The only issues with them are usually the controls and wiring, pay particular attention at hinge points and make sure the control wire is secured in all places, not binding up anywhere. Also in case you get stuck in the up position, make sure you know where the manual release is so someone on the ground can let you down. Definitely get the books on it if you don't have em already.
CWL
10-03-2007 05:11:22
I'm sure you already know this from reading your past posts, but I'll stick my nose in anyway. It would be a good idea to put leveling jacks on all four corners of the trailer. A sissor lift is great, but they need to be level and on a firm foundation. Sounds like your going to have a great setup!
Slowpoke
10-12-2007 18:55:46
 Re: Sissor Lifts in reply to CWL, 10-03-2007 05:11:22
I think the scissor lift needs to be removed from the trailer to use it.
T_Bone
10-03-2007 06:15:06
Hi CWL,
Your nose is always welcome.
Sounds like some out riggers would work here.
When he said it had it's own trailer, all I could think of is, ohh great more tires too buy.
T_Bone
