Link Link Above are two links to former posts on this MB that I think will help you with welding cast iron. For this type of repair which is more replacing missing metal as opposed to repairing a break that extends through the metal you're getting off easier. You need to control the heating and cooling of the piece so you don't end up breaking it from stress. Based on my past eperience with similar items, Clean as normal with grinder/wire brush to remove any slag and then a chemical clean to remove the oils. You should heat the part completely to around 400F before welding. For this you can use about any type of cast iron electrode because you don't have to machine it at all. A high nickle will probably be best but I'll leave that answer for Steve from US Alloys. Run short stiches of weld only 1/2" - 3/4" long at a time opposite each other as not get a big HAZ (heat effected zone), use the lowest amperage setting possible so that the rod barely maintains an arc. Immediately following you stopping the bead, use either a chipping hammer with the pointed end or a needle gun to peen the weld and to both sides of it. Don't beat the piece to death but don't go too light either. I prefer using a needle gun running around 65 psig of air, this is fastest and maintains a steady peen action. Try to maintain the steady 400F all the time on the part during the welding process. Once done with the welding, cool the part slowly by reducing the pre-heat a little at a time and keep the part out of a draft or other ambient or compressed air flows. Using the small stiches, you'll not only keep the heat down but have less of a chance of warping the part too. Good luck!
