Tool Talk Discussion Forum
I bought a Hobart 210 mig welder- and i love it
RobMD
09-28-2007 16:35:56
I opted to save $356 on a Miller 210 welder by going with the equivalent Hobart 210 welder from Northern Industrial tools.
Everything on this Hobart welder is made in the USA and the gun is from Canada. I called a Hobart technician, and he said all it is is an inexpensive version of the Miller welder. Compared with a buddy's 210 Miller side by side. No differences between the Miller and Hobart WHATSOEVER. No and's, if's, or but's about it.
I am satisfied with Northern's 3 day shipping on this welder through Yellow freight.
dboll
10-01-2007 06:01:28
 Re: I bought a Hobart 210 mig welder- and i love it in reply to RobMD, 09-28-2007 16:35:56
I thought about buying a Hobart but found a nearly new Miller 250X for $1300.00 3 years ago. The Miller and Hobart are similar but the wire feed on a Hobart is cheaper built with plastic instead of steel rollers but you can put the Miller drive in a Hobart.
Don-Wi
10-01-2007 00:51:36
We've got an Arc One welder about the same size. It's another one made by Miller, still blue, just a different sticker on the side.
I don't use it too awfull much, but on thin stuff it works great. We've got the old Miller Thunderbolt for the heavier welding, or I'll take it to work and fry it with the big mig. No worries about slag that way...
Donovan from Wisconsin
K.W.
09-29-2007 09:12:56
I got a Hobart gas driven unit it has been good to me so far. Also got a old old forney welder. must be pretty old by the looks, Im guessin 50's maybe. It is a stick welder with dial adjust, and has been a good one to. Anyone ever heard of them?
Stan in Oly, WA
09-30-2007 09:58:25
 Re: I bought a Hobart 210 mig welder- and i love it in reply to K.W., 09-29-2007 09:12:56
Hi K.W.,
Heard of Forney welders, or heard of Forney welders with dial adjustment? Yes/no respectively. All the Forney stick welders I've ever seen have been huge, heavy, virtually indestructible red machines with taps for setting the amperage. You plugged your electrode lead into the outlet that had the amperage you wanted printed beside it. No moving parts, in other words (I don't know if they even had fans.)
There's still a Forney company but they aren't in the welder manufacturing business any more. Whatever happened to them happened long before most Americans stopped caring about sturdy and reliable as qualities they looked for in a product, so it wasn't that.
All the best, Stan
railhead
10-02-2007 19:46:30
 Re: I bought a Hobart 210 mig welder- and i love it in reply to Stan in Oly, WA, 09-30-2007 09:58:25
Hi Stan, No Forney welders I own have fans and I have never seen one with a dial control. I have now 5 Forneys, have owned a few more, never had one that didn't work and weld (lucky I guess). You are right, they are nearly indestructible (within reason). I greatly admire the whole Forney family story of manufacturing. They are a symbol of America as it SHOULD have been forever.
Sure some of these new (hobrat) welders may be assembled in USA but if the imported parts were left out they wouldn't weld nor even bolt together. We are fading.
Stan in Oly, WA
09-28-2007 21:23:30
Hi Rob,
Sounds great! I expect you bought an Ironman because you mentioned not thinking you needed the 250, and the Ironman series comes in both 210 and 250. I ask because when I went to the Northern Tool site to see what your welder looked like, there was also a Hobart Handler 210 MIG there. The configuration of the two machines suggests that the Ironman is the more serious welder, even if the difference in price didn't already say that.
My only Hobart welder is a Stickmate AC/DC machine which I have been completely satisfied with. Among its other good qualities, it must be relatively efficient because it generally won't trip the 30 amp breaker on the outlet I can use so I can weld in the driveway. Several Lincoln 225 amp AC buzz boxes I have owned all trip that breaker unless I am very, very careful.
Again, congratulations, Stan
djfarmer
09-28-2007 17:44:12
My Miller 210 is blue, not tan like the Hobart!
RobMD
09-28-2007 17:49:15
 Re: I bought a Hobart 210 mig welder- and i love it in reply to djfarmer, 09-28-2007 17:44:12
Hobart is white.
djfarmer
09-28-2007 17:54:54
 Re: I bought a Hobart 210 mig welder- and i love it in reply to RobMD, 09-28-2007 17:49:15
I guess I am going to have to get busy and clean my old Stickmate.
Bob
09-28-2007 17:03:32
I have a 250 Amp Hobart Beta-Mig, and it's been a GREAT welder.
RobMD
09-28-2007 17:09:05
 Re: I bought a Hobart 210 mig welder- and i love it in reply to Bob, 09-28-2007 17:03:32
Cannot believe the success I am having over the old mongomery wards 295 amp stick welder.
I can lay smooth welds with my 75%/25% ar/co2 sheilding. I've just done sheet metal work with minimal warpage.
I would have gotten the 250, but I really don't think I'll need that duty cycle time.
