Tool Talk Discussion Forum
Cheap drill press
SDE
09-28-2007 06:46:31
I bought a 16 spd Cummins. First hole I tried to drill in metal, the v-belt twisted/flipped and now it will not run straight.
What causes this to happen?
Belt to loose, or to tight, or is it because of a mis-alignment between the two pulleys?
Thank you SDE
Gene Davis (GA)
09-30-2007 19:44:04
 Re: Cheap drill press in reply to SDE, 09-28-2007 06:46:31
Sounds like you have a problem with the fabric cords in the v-belt. Mismatched or broken cords will cause them to roll like a dog in the groove of the pulley.
X22
09-29-2007 16:11:46
You may have a bent spindle or pulley.
akb
09-28-2007 23:14:50
Did you get it at the VFW in Princeton
was there today alot of junk
SDE
09-28-2007 07:22:07
Thank you for the quick replies.
The belt did not appear to be too tight when I started. After it flipped, I tighten it, but it was too late by then.
I thought it should have slipped also, but it did not slip until after it flipped.
I did not want to buy a new belt until I knew why the first belt did not work.
How do you check for proper alignment? Use a straight edge across the top of the two pulleys?
Thank you again Time to head to town to buy a new one,(belt).
SDE
carwash tech
09-28-2007 06:54:32
#1 - mis-alignment of pulleys
#2 - a pulley loose on its shaft
A loose belt should slip, but will probably not flip. -- A tight belt will probably not flip, but will put strain on the bearings/bushings.
sde
09-28-2007 17:48:11
 Re: Cheap drill press in reply to carwash tech, 09-28-2007 06:54:32
The pulley was loose. I did not try to drill anything yet. I am optimistic about it being ok though.
Thank you SDE
Bob
09-28-2007 06:58:02
POSSIBILY a bad belt, as well. If some cords break in the belt, it will always try to flip over on it's side.
