Pto hp John Deere 2010 tractor
tom smallman
06-21-2001 21:03:27
I would like to know if the rated engine hp is the same as the hp generated at the 540 rpm pto??
Can anyone help?
TVS
Red Dave
06-23-2001 06:14:04
 Re: pto hp John Deere 2010 tractor in reply to tom smallman, 06-21-2001 21:03:27
No, they are not the same. PTO HP is the HP available at the PTO at it's rated rpm. It gives a measurement of power after driveline friction losses have been accounted for. Engine HP is the HP avilable at the flywheel with the engine basically running wide open, or close to it. It is a measurment of the motor only and does not take into account any losses external to the engine. Belt pulley HP is the same as PTO except measured at the pulley instead of the PTO. Belt Pulley/PTO HP and drawbar HP ratings were developed to give a reasonably fair and accurate comparison of the amount of work a total machine could do, not the theoretical power at the flywheel. I guess advertising departments liked to stretch the truth back then too.
Burrhead
06-22-2001 08:16:50
The book gives the 2010 as PTO 47hp and drawbar is 40hp if that's what you mean.
Ray,IN
06-22-2001 20:04:53
 Re: Re: pto hp John Deere 2010 tractor in reply to Burrhead, 06-22-2001 08:16:50
There are 5 methods for determining HP. Measured engine HP,belt HP,PTO HP,drawbar HP; then there's the Nebraska tests, supposedly the most meaningful of all. None of these are comparable as each involves quite different circumstances.
