Tool Talk Discussion Forum
Burned up my Weller 60W
Aaron Ford
09-26-2007 19:58:07
I was soldering some wires this afternoon and picked up my iron only to find it cold, well, lukewarm. It is a 7500 336B with a fine tip. Any thoughts on where to find a new one that won't break the bank? I am looking at ebay, but most seem to come with a huge tip. Are they easy to change? Thanks Aaron
Chuck UR
09-27-2007 04:39:21
 Re: Burned up my Weller 60W in reply to Aaron Ford, 09-26-2007 19:58:07
I agree with Chris(WA).
I've got a big speed job that quits now and then.
I take out the tip clean everything up and it works like new.
Vern-MI
09-27-2007 02:23:53
Try Electronix online...
MarkB_MI
09-26-2007 21:56:47
I'm a big fan of the Weller WTCPT soldering stations; these temperature-controlled irons are the only ones I will use on printed circuit boards. The temperature is controlled by changing the tip, which makes temperature control very precise. They are a bit overkill if you're not working on electronics, however.
I googled on "weller soldering station" and got a bunch of hits. This company linked below has a wide selection of Weller irons and parts. I'll bet they have a replacement element for your iron.
old_bc
09-26-2007 21:34:08
Try the link below. I think this is what you need. We use these at work and the heating element screws in.
old_bc
http://www.newark.com/jsp/level5/module.jsp?moduleId=en_US/5888.xml
Chris(WA)
09-26-2007 20:41:46
Usually on an iron the tip just screws in kind of like a light bulb. On a gun they are nutted on. Lots of times the come loose and make poor contact which is why they don"t heat.
JoeK(WI)
09-26-2007 21:36:01
 Re: Burned up my Weller 60W in reply to Chris(WA), 09-26-2007 20:41:46
Do you happen to know the model no? Weller is owned by Cooper Hand Tools and parts(tips.coil,thermocouple etc)should be available.
Might try True Value Hdwr as I think Cooper owns them too.
TimWafer
09-27-2007 05:43:40
 Re: Burned up my Weller 60W in reply to JoeK(WI), 09-26-2007 21:36:01
Cooper tools does make Weller solder irons and they are carried in most True Value Hardware stores but I can assure you Cooper does not own True Value nor vica-versa. True Value originated as Cotter & Co. a co-op under its founder John Cotter. Several years ago it merged with several other hardware chains and became Tru-Serv. Now it�s changed its name back to True Value and is still a co-op.
JoeK(WI)
09-28-2007 19:25:41
 Oops...My bad in reply to TimWafer, 09-27-2007 05:43:40
Cotter vs Cooper.....shoulda remembered,useta have a Cotter credit card when we had a T.V.
