Tool Talk Discussion Forum
OT- - Dry Drain in Laundry Room...
fepo
09-26-2007 19:23:46
Hi,
Thought I would run this by you folks. My drain in laundry room, located in basement, keeps drying out a few times a year, I add water and it takes care of it for a few months. (to block the sewer smell, also there is no back flow valve)
Does anyone have a better idea to make the water/liquid in the drain last longer? like adding some oil to create a film to slow evaporation... or using RV/pool anti-freeze instead of water or other product? any thoughts welcome...
Thanks!
Fred
msb
09-27-2007 19:28:21
 Re: OT- - Dry Drain in Laundry Room... in reply to fepo, 09-26-2007 19:23:46
Any vegetable oil like soybean or Canola oil will work. Put a couple inches in it.
fepo
09-27-2007 16:04:05
Thanks for the info. Looks like I'll give the mineral oil a try... I dont really want to plug the drain since it may come in useful one day if the washing machine hose breaks...
Also found a product made in Canada called Dranjer, but I doubt I will find it where I am, so will keep an eye out for it. It lets water in but seals up when no water is flowing in.
Scott.ID
09-27-2007 15:20:37
third party image
Try a "test plug" from HD or any place else that sells plumbing supplies.
It's an expanding rubber plug with a metal plate and a wing nut on the top. Slip it in the drain, tighten the nut and call it good. You might have to refill the trap once a year, but the plug will stop the evaporation and it's easy to remove and replace.
Plumbers use them to test DWV systems for the inspectors. You should be able to find one for 2-3 bucks.
My nickels worth,
Scott
NE IA Dave
09-27-2007 15:11:31
I always suggest you should not fix the leaking faucet for the wife--now you have a valid excuse.
I was at a birthday party once and a young couple with a small baby was getting blamed for not changing the baby (behind their backs I should say) turned out that no one had used the basment drain for a long time.
rhouston
09-27-2007 09:33:03
how about a 99 cent rubber drain stopper. If it's going dry you must not use it much. When you use it remove the stopper otherwise just leave it installed.
rhouston
09-27-2007 09:35:39
 DUH in reply to rhouston, 09-27-2007 09:33:03
Just realized you are talking about a floor drain rather than a laundry tub.
matthies
09-27-2007 07:37:07
I've been told to put mineral oil in the drains.
Mattlt
09-27-2007 05:52:41
I commend you on knowing that the trap was dry. This happened in my office one time, where a trap under an unused coffee pot location went dry. Our office manager was ready to call a plumber. She asked me to look at it. Pouring a couple glasses of water in it was all it took.
Nicklan
09-27-2007 05:05:16
Pour a little vegatable oil down the drain, it will prevent the water from evaporating.
Nick
TomR Ont
09-27-2007 02:07:38
fepo, you can buy a tap with a petcock on the side of it, and every time the tap is turned on some water goes in the tap. Of course you have to connect a small hose to it and down to the trap.
This should have been done before the floor was poured
leroy in ne
09-26-2007 19:35:22
my experiance is rv antifreeze will evaporate like water does however propolene glycol antifreeze might be suitable, this is the environmentaly friendly stuff (sierra brand)? not ethelene glycol which is a poison and should not be used where consumption by pets, kids and wild life might be possible besides violating polution laws if introduced into sewage system
