Tool Talk Discussion Forum
wagner 2 spool valve help
railhead
09-24-2007 19:36:25
Does anyone know a website or know of a place to see diagams for wagner spool valves? I bought one for my loaderthat I cannot get to work and it was sworn good. I need to know what is the inlet and outlet. It is open center. No ports are labeled and I have about tired of changing and changing nad changing hyd hoses to no avail. THANKS!!!
caterpillar guy
09-25-2007 10:39:54
 Re: wagner 2 spool valve help in reply to railhead, 09-24-2007 19:36:25
IS this for a open or closed center system that could be a difference. Otherwise the left port should be pressure right return top or bottom to the cylinders or couplers switch the hoses to cylinders for direction correction.
BuddyBear
09-25-2007 09:15:02
wagnercompanies.com/web_log.aspx
Will give you an IPC. Should be of some help.
Otherwise if the valve is off the loader, try pulling the lever and shooting some air in various ports till air comes out the other one.
RegoR
09-25-2007 12:38:26
 Re: wagner 2 spool valve help in reply to BuddyBear, 09-25-2007 09:15:02
GREAT link! Thank you!
