Tool Talk Discussion Forum
Underground Electric Wire for Bin
super99
09-21-2007 17:04:05
I am finally ready to wire up my grain bin. A old retired ex electrician is going to coach me along after I get wire buried and conduit put on, all boxes and controls are already on the bin ( it was a used bin that I took down and moved and put all boxes back on, just need to get power to everthing). He said I need to bury wire 3 ft. deep. I was thinking more like 16 to 18 inches, I was going to dig it in by hand, but if I have to go that deep, I'll have to rent a trencher. I can't imagine anything being done where the wire will be buried to disturb it, Do I need to go that deep? Your thoughts please, Chris
caterpillar guy
09-23-2007 08:11:48
 Re: Underground Electric Wire for Bin in reply to super99, 09-21-2007 17:04:05
If you run it in conduit and need to change the wire for any reason It can be done with out diging it up again,and your already talking about adding to the curcuit load with more fans for an additional heater. Just be sure to use big enough conduit for the job also after the wire is in before you cut it off push it back into the pipe a bit that way you have slack for expansion and to work with. If you use pipe for it(conduit) it will protect the wire from the hazards mentioned above (stones &such)
Denny 2
09-22-2007 06:49:40
Dont forget to drive ground rods at the bin. As soon as you go with 2 or more circuts the NEC requries a ground rod or rods depening on the local code. Where you land the ground rod wire depends on how many wires you take to the panel. Make sure you know the difference between grounding and bonding and also between grounded and grounding wires.
msb
09-21-2007 19:55:13
Code says 2 ft. deep. Frost should not be a concern at all.If the soil heaves, the wire is going to heave right along with the soil. Not a problem the wire has some slack to it. That is why you snake the wire in the trench.Am rewiring my bins and the old service is only about a foot deep and it has been there since the mid 60s. The one is an old Truelock bin.The other is a Superior and both have been out of business for decades.In my opinion, I would be more concerned about rats burrowing into and chewing the insulation.Just be sure to use either USE or UF designation wire.Both can be direct buried, but rigid conduit must be used above ground and extend to the burial deepth of the wire. I use a 90 elbow to end the conduit run in the ground. If this in a non traffic area, you can safely go to a 1 foot burial depth in my opinion.
super99
09-21-2007 17:30:10
Frost level is 3 ft. We are out in the far end of the county( Rock Island, Ill) and it's zoned agriculture, so I was told that you can do about whatever you want to. The soil is sandy, about all that used to grow on it was sandburs. Chris
old
09-21-2007 18:36:59
 Re: Underground Electric Wire for Bin in reply to super99, 09-21-2007 17:30:10
If frost level is 3 foot you need to go at least that deep or the freezeing will cause you BIG problem and brake the wire or cause a line leak which will cost you BIG $$ from draining power into the ground and or get some one hurt
CNKS
09-21-2007 17:22:54
Whatever the code says in your area.
3000OH
09-21-2007 18:24:12
 Re: Underground Electric Wire for Bin in reply to CNKS, 09-21-2007 17:22:54
CNKS is correct. You don"t say what voltage/amps it"s got to carry, or the distance. Also, are you going to be driving over it? Around here, a 220V/200A feed to a barn goes 3+" down and, if it"s going to get any traffic over it, then that part goes in conduit, too. Electric Co told me they"d seen too many cases of "oh, it won"t hurt" but the shifting caused by tire traffic slowly but surely pushed rocks into the cable, causing a short. That"s another point - keep all rocks & gravel out of the backfill if it"s not in conduit, and snake the cable to help keep it from being stretched during settling.
The NEC (Nat"l Electric Code) is largely written from a safety perspective and is based on hard and too-often fatal lessons that have been learned. Futzing around it doesn"t mean you"ll absolutlely get hurt but, if you (or someone else) does get hurt, you can expect your insurance company to bail out on backing you.
HTH
Bus Driver
09-22-2007 05:05:28
 Re: Underground Electric Wire for Bin in reply to 3000OH, 09-21-2007 18:24:12
Local codes may differ. But the NEC specifies that direct buried conductors up to 600 volts are to be buried with a minimum burial depth of 24". Burial at greater depths is not required by the NEC. Other conditions/materials may be at lesser depths. Article/Table 300.5.
super99
09-22-2007 04:54:02
The length of the run is 140 ft. The bin has 3 motors, 10 hp fan, 5hp unload auger and a 1 1/2hp for transfer auger. I was told to get 4/0 Alum wire and run it to a 200 amp breaker box and then split it down to smaller wires to motors and controls. Wire will run around the front of machine shed and under driveway. Planned to put conduit under the driveway to protect wire. The soil is so sandy that you had to be careful driving a pickup across it or you would get stuck, so before putting up shed and bin, I covered it with 12 to 18 inches of good black dirt. Once you get thru the good dirt, I'm not sure you can get 3 ft deep with out it caving off and then have to dig a trench 2 or 3 ft wide to get to that depth. When my well was put in( right next to shed), the driller told me there waqs 33 ft of sand there before he hit any dirt, so I don't think frost heave will be any problem. Did I leave out any more info you need? The bin has a Shivvers unit in it and at some point I might want to add another bin with drying floor so there may be another drying fan hooked up to it sometime. Chris
3000OH
09-24-2007 17:17:48
 Re: Underground Electric Wire for Bin in reply to super99, 09-22-2007 04:54:02
Sorry. That kind of load is beyond what I know how to figure, ditto for installation. Time to talk to a real sparky guy.
ferrell freeman
09-21-2007 17:13:08
What does the local & state electrical code call for. The other thing is if you have insurance and something happens their always looking ways to get out of paying.
old
09-21-2007 17:07:28
All depends on what is call frost level. No matter what you need to bury it below frost level or you will have problems with it. In my area 18-24 inches is just fine but frost level is said to be 18 inches.
