Tool Talk Discussion Forum
Need a pump of some kind
JimDril
09-19-2007 18:22:21
I need to fill gallon milk jugs with water from a rain barrel, about 40 at one time. I've been dipping them, but this gets somewhat tedious, especially when the barrel gets low. I was wondering if I could get some kind of electric pump that I could drop a hose in the barrel and fill the jugs quickly. I've got the emties lined up in a trailer.
caterpillar guy
09-23-2007 08:48:39
 Re: Need a pump of some kind in reply to JimDril, 09-19-2007 18:22:21
Just put some tee's in line with a shut off from barrel then put a plank or such down under the tee's with the jugs under tee's should fill all at once might need to be able to stop some or all seperately.
BigMarv1085
09-20-2007 13:38:50
I saw a sump pump for a basement at our local wal mart for $39.99.
bcPA
09-20-2007 09:16:40
raise barrel up on blocks and use a siphon hose. They sell a neat hose with a marbel check valve built in to it, but I think it cost too much for what it is. You can weight the end of hose in barrel and put a valve on the other end of hose and only have to start water flow once.
Mattlt
09-20-2007 05:48:06
How about an RV style (also sprayer) pump? They are 12V, and have an auto shutoff. Rig up a garden hose style pistol grip nozzle and fill your jugs. The pump will shut itself off when you close the nozzle. Should be in the $50-60 range.
They are a little slower than the bilge pumps, however. 1-3GPM range. Guess that would take a while to fill 40 gallon jugs...
rockyhawaii
09-19-2007 20:49:45
As Pooh Bear said, a submersible bilge pump will do fine. I use one to change the water in a fish pond and it lifts the water. Just hook up a 12 volt battery and the hose.
Pooh Bear
09-19-2007 20:11:38
I went to wally world last spring and got a 1250gph bilge pump
from the sporting goods section for $20. Been using it all summer
to fill up two 55 gallon barrels mounted on a trailer.
I tow the trailer down to the river with the 4 wheeler and fill the barrels,
then tow it back up to the garden to water the tomatoes.
Pooh Bear
landlord7012
09-19-2007 18:55:24
a 12 volt bilge pump works good. You could hook up to your car/truck/garden tractor/atv etc. Not sure what exactly you are watering but I started out with gallon jugs too. I advanced to a 55 gallon drum with a 150 gph bilge pump on my atv and finally to a 250 gallon container with a 8 gpm agricultural pump. Next step is electricity and a well but I'm having fun for now!
ll
Help needed
09-19-2007 18:43:17
If you have electricity. one of the cheap sump type pumps would be perfect. I guess even one of those cheap drill chuck pumps might work but my vote is for a cheap sump pump. Hook a hose pipe to it and drop it in the barrel and pump pump pump.
