Tool Talk Discussion Forum
Windows Vista and Dial-up
T_Bone
09-19-2007 14:41:09
Smoked another puter this past month and bought a new Toshiba dual core with Win Vista. What a headache Vista is. XP had a very short learning curve comparred to Vista. XP smokes Vista in preformance value.
A known problem in Vista while using a dial-up modem, either internal or external, is the modem hangs after 10min to 20min use. To correct you must disconnect from the ISP and reconnect.
After many hours of reading, ((after a clean boot)), I some times can get 1hr use before the modem quits DL'ing. The modem usually will always keep UL'ing tho...lol
Vista blames the OEM modem/puter mfg for the errors and the OEM blames Vista. I'm sreaming at Toshiba to give me a copy of XP and drivers to work with there new lap top. we'll see!
Alot of the Vista software (add on's) will "not" stop trying to update there programs once they start running. Now were talking several megs of update files. On a dial-up that's just about impossible unless you want to spend a few days DL'ing "unwanted" upgrades. Geez I just took this new puter out of the box and you would think I'd atleast last 30days without a upgrade.
MS will DL Vista updates wheather you want them or not. I checked for Vista updates and mine required 87megs of updates at ONE time! I choose not to update thinking MS will cut a CD with critical updates for a small fee. Then I read where MS will automatic DL what ever they feel is necessary WITHOUT your premission and with having auto update turned off.
Overall, if the dial-up modem worked like it should, I would probably live with Vista(Premium) and put up with the slow learning curve. Vista does have some improvements over XP but XP(home) with add on's is hard to beat.
Try to find a new laptop with XP is almost impossible unless it was a open box or return or you want to spend $1500.
T_Bone
Gary in Geneva
09-26-2007 15:22:11
 Re: Windows Vista and Dial-up in reply to T_Bone, 09-19-2007 14:41:09
T-Bone,
Windows XP has over 88 updates that would need to be applied � something over 130MB.
With Vista MS is trying to keep people safe by applying critical updates. On dial-up it will take a L O N G time to get caught up to date. Manufactures of computers do not apply the updates before sending them out, so the end users need to.
My recommendation is to find a free high speed wireless connection and download all of the outstanding updates. Then reboot, and do it again until you have all of the updates. You will want to do the Microsoft update so it will also get the updates for Office as well. Check for any hardware updates in the list. If there are some you may wish to install them as well.
Once you are caught up things should be better. You may want to look ad the dial-up settings and see if it is set to disconnect when idle after 20 min � if so set it NOT to disconnect.
Your advice has helped me in the past, and I hope I can return the favor. Email if you would like to.
Gary
Howard H.
09-20-2007 19:21:15
Yep - I think most of the changes in Vista were for Microsoft's benefit, not the average user.
But, for what it's worth, I've seen modems exhibit that behaviour back to Windows 98. On one PC in particular, I fought for several months, with everything from OS reinstalls to checking the outside cabling to trying another modem of the same type - it was finally cured by going from 2.2399.232390a to 2.2399.232390a1 (or whatever the tiny change at the end of the version # was) from Dell - and that was after a new driver about every 2 weeks for the past 4 months.
Also, keep in mind even though you might have a Xytel modem (or whatever), sometimes the original manufacturer of the PC itself will "tweak" the drivers to their own flavor because of some peculiarity designed into their system and you must use their's only...
Also, you don't have call waiting or anything that can generate a tone on the line while you are hooked up, do you?? Sometimes that can cause them to hang...
Howard
unioncreek
09-20-2007 06:12:54
Your modem is the problem with the dial-up. We just bought a new Acer laptop with Vista and haven't had the dial-up problem. As far as updates for Vista that can be shut off if you go to Control Panel and then Windows updates. We're on dial-up also, but the laptop has also has a wireless connections, so we just go to where we can get a connections and do our upgrades.
Bobg
T_Bone
09-20-2007 11:41:16
 Re: Windows Vista and Dial-up in reply to unioncreek, 09-20-2007 06:12:54
Hi Bob,
Yes you can turn off updates but MS "CAN" still DL updates with the settings turned off. This just hit the RV forums last week that MS has a Vista back door for there use.
My concern is, who else will use that back door?
I now have a "off line" puter for my finance books that will never go on line. That solves that worry.
T_Bone
Mattlt
09-20-2007 05:54:07
Hi T_Bone,
Assuming this is a new internal modem? It's possible there's some kind of "keep alive" setting, or in this case the lack thereof, that is timing out. Might need to dig into some of the modem settings to figure this one out.
Aren't computers wonderful?
T_Bone
09-20-2007 11:51:10
 Re: Windows Vista and Dial-up in reply to Mattlt, 09-20-2007 05:54:07
Hi Matt,
I've been inside and out in just about every control I know about and a few that I didn't know about.
So far I haven't found any easy to find timers. I'm still looking tho...lol
Ohh ya, they get me hooked on paperless, bill pay, electronic stock trading and it's a never ending fight just to have this convenience. If I was still working I'd have to go back to paper!
T_Bone
old_bc
09-19-2007 21:35:47
Change your Vista to the Windows Classic look and it is a little easier to use. The classic look is more like Windows XP.
old_bc
Rae Norman
09-19-2007 17:55:59
Get a MAC and leave your troubles behind. Also better security.
Coloken
09-19-2007 18:46:38
 Re: Windows Vista and Dial-up in reply to Rae Norman, 09-19-2007 17:55:59
Better yet go to Linux..get Ubuntu disk for about 5 buck and save thousands of dollars.
onefarmer
09-19-2007 17:31:22
I"m running Vista now, mostly because my old computer died and the new one is 64bit. I had already bought Vista to learn it for my ISP job and it came with a 64bit disk.
I am now looking for a 64bit XP. Even with this nice new computer with 4Gig of ram it is slower than XP on my laptop that has a 2.4g processor and 512ram.
I would never recommend Vista to anyone until MS quits supporting XP, but they will have the next mess out by then.
Coloken
09-19-2007 17:09:45
Ken, I have used, tried Vista since it came out. On several computers, mostly on the 30 day trial thing (big grin) At the present time I can not think of any reason to use it over XP. Me and friends have found that most older mother boards do not have drivers available, like sound. Last one I heard was the dial-up program for a fellow was not available for Vista. It gets to be APA. The 87 meg of updates is common and can do it again in week or so. It never quits that. If they won't find you a copy of XP, My recomendation is find you a bootleg copy of XP and format. Kenny
T_Bone
09-20-2007 12:12:04
 Re: Windows Vista and Dial-up in reply to Coloken, 09-19-2007 17:09:45
Hi Kenny,
I was just talking with Toshiba yesterday and the only XP driver available is a modem driver. He said the DVD may/may not work with XP common drivers. All the other puter hardware would not work after a XP install, wi-fi and either net, sound, and ???
Another problem is, once you take out the original Vista formating, the the Vista recovery disc will no longer work and you'd have to send in the puter for Toshiba to fix. $200 was the quote. I did that on my XP Toshiba and thought the OEM disc was bad. Solved that by buying a MS copy of XP.
I'm looking into dual boot now.
T_Bone
Coloken
09-20-2007 13:15:21
 Re: Windows Vista and Dial-up in reply to T_Bone, 09-20-2007 12:12:04
Ken, watch out when trying dual boot. Vista has a whole diferent way to boot. Some dual boot programs don't work. I have a computer here with XP on the C drive, then installed Vista on the D partition. Gives me dual boot--It asks "boot Vista or do you want the "older boot"" . I even have a choice of Linux on the third partition. To leave the original Vista alone might be a no go. This is getting like tractors,,,the new ones are hard to live with and the old classics are so much simplier. Kennyp
Bob - MI
09-19-2007 14:53:56
I have found that XP Pro machines are still available but you have to buy them from the business sites of Dell and Gateway.
I have been looking at buying my college senior daughter a new laptop and I don"t want to go through the headaches of a new operating system. She calls home sometimes now and asks me how to do things on her desktop with XP. I can just go to mine and walk through the steps and help her out. Her school just switched all the software over to Office 2007 and didn"t announce they were doing it. Now anything they do remotely like at the library is handled as "read only" files by her Office 2003 machine at home.
It never ends..... .....
onefarmer
09-19-2007 17:36:08
 Re: Windows Vista and Dial-up in reply to Bob - MI, 09-19-2007 14:53:56
Bob she should be able to save her file as an earlier version format. When she goes to save the file, in the "Save File As" drop down their should be choices for earlier versions
Bob - MI
09-20-2007 06:09:40
 Re: Windows Vista and Dial-up in reply to onefarmer, 09-19-2007 17:36:08
Thanks for the tip. She was going to get the 2007 version but if she hasn"t done that I will have her start saving changes in the right format.
They get any Microsoft title out there for $10.00.
onefarmer
09-20-2007 07:03:52
 Re: Windows Vista and Dial-up in reply to Bob - MI, 09-20-2007 06:09:40
For $10 get 2007 for sure.
