Do it for a living most of the time. You can use all the other answers, but Clark has a electric tin snips. I got one last Friday at TSC for $49.00. That is ten dollars cheaper than my first Millwalkee replacment blades were in 1971. They are interchangable and made by the same company. They work great for length way cuts. We use a cement saw for cross cuts. and you can cut 50 plus sheets at a time. Using tin snips is easy for single cross cuts. Many do not understand the tin snip 101 lesson. If you are making a cut with the small scrap on your left you should use the green handled version on a lot of popular brands. When cutting, throw it on the grass and ---LIFT___ the scrap a little higher with your left hand as you cut and hold the big panel down with your knee. If you do not lift the scrap it will bind. As you cut, the scrap should lift with your snips jaw that is lifting upwards --NOT the jaw that is going downwards. The Right hand cut snip are commonly green. The Right side of you snips will lift--the scrap up so you hold down the pannel with your left knee. The color of the snips is not always Red or green, and yellow for straight, but remember your snips jaw should raise your scrap. I have a metal cutting skillsaw and it works ok, but the guard does not have a lever to lift when it catches on something and is alot of times a pain. When we used to use a skill saw with a carbide blade we never turned it around because it will try to climb up on the pannel if you crowed it to hard, and it tends to burn the paint a little.
