Tool Talk Discussion Forum
Need Refrigerator Advice
Jim in NC
09-14-2007 06:10:17
I have water dripping from the freezer compartment, perhaps coming from the defrost process. The drip tube is clear as I have cleaned it out. The water enters about a foot to the right of the drip tube and about 6-8 inches from the back. This is a Kenmore made by Whirlpool. It has age , but it cools and works fine otherwise. Thanks for your help.
Slowpoke
09-22-2007 01:40:25
 Re: Need Refrigerator Advice in reply to Jim in NC, 09-14-2007 06:10:17
I assume you have a top freezer....and the water is dripping down on the food in the cold box or running down the walls. You may have one or two problems. The first and most likely is that the defrost drain is plugged with food trash that has gotten under the freezer floor plate thru the vents. The second is a drain heater has failed and the drain is blocked with ice. But you may not have a drain heater. A Phillips screw driver with an 18" shaft will make the job of removing the back plate easy. Be sure to follow Stan's advice and note which screws go where, have washers or different threads. Also be sure to unplug the refer before working on it as there could be 120 volts on the defrost heaters.
Towman
09-16-2007 04:31:36
Would suggest a trip here>Link
Towman
Ludwig
09-15-2007 12:35:02
I have EXACTLY the same problem. We keep a pan in the fridge the catch the water. Lousy solution. I'll be looking into the door seal.
T_Bone
09-14-2007 10:57:52
Hi Jim,
Excessive water draining after a defrost cycle is a good indication that the door gasket is leaking.
There are two adjustments. The door hinges. When adjusted correctly, a piece of paper closed in the door seal should have resistance to be pulled out while the door is shut.
If the hinges don"t correct all the alignment problems, then under the gasket there are a series of screws around the door frame. Loosen all the screws and apply pressure to the door in the direction for correct alignment, then tighten the screws.
Replace gasket if the above fails to resolve your problem.
T_Bone
Stan in Oly, WA
09-14-2007 07:47:59
Hi Jim,
A few years ago I worked at an apartment complex where that was a common problem. All the refrigerators were 10 years old (the age of the complex) and cheap---cost only $400 to replace. I didn't know about hanging the copper wire down the drain but we did the other things that people have advised you. The second (and final) full year that I worked there the failure rate of units with problems went up to nearly 50%---they just couldn't be fixed doing what had usually worked previously.
If you disassemble the freezer compartment to defrost and to remove debris, pay attention to the order in which things come out and to which screws go where. If you install the floor and back and baffles in the wrong order, you have to take them back out before you can get everything back together. Also, you can make the long screws work where the short ones came from, but not vice versa.
Years ago I had a self defrosting fridge that stopped self defrosting. The fastest easy way I found to defrost it quickly enough so that I could leave the food in the refrigerator compartment was to take all the food out of the freezer, put a trouble light in, and close the door. After an hour or so I could take out all the chunks of ice that had been in the freezer compartment, and a few hours later the ice on the coils and behind the back baffle would be melted.
All the best, Stan
joe fabregas
09-14-2007 06:56:57
We had a fridgedaire that started doing that. The insulation between the freezer and the fridge was white styrofoam and became water-logged. It would then drip all over. Changed it out at great expense and consternation but that went south after awhile too. Good luck! joe in ny
joe fabregas
09-14-2007 06:50:20
We had a fridgedaire that started that. The insulation between the freezer and the fridge was white styrofoam that became waterlogged over the years and would drip where-ever it felt like. Changed it out at great expense but eventually the new one went south. Good luck! joe in ny
lucas boy
09-14-2007 06:48:53
mine was doing that, i had to take the bottom cover off inside the freezer and clean it out where it defrosts and drains. lucas
lab
09-14-2007 06:44:40
We have a kenmore refrigerator about 6 or 7 years old and it is self defrost.When it went into defrost it would drip on the top shelf. The drain line was froze up and a repairman told me to take a small piece of copper electric wire, strip coating off and hang on tube above drain and let it hang down into the drain. When it goes into defrost mode wire will heat up and keep drain open. This has worked for us for about 3 years now
