Tool Talk Discussion Forum
Clamping black poly water supply line
Stan in Oly, WA
09-13-2007 21:15:41
A woman who works with my wife called yesterday because she had discovered that there was a leak in the water supply line to her house. I didn't want to have anything to do with it, but it would have been a little like throwing her to the wolves to leave her to the mercy of whatever plumber she would get from the yellow pages.
I went there this morning, dug up the soggy spot and found the leak. The supply line was 1" black poly pipe---the kind that comes in coils, and not the heaviest grade either. I cut the line at the leak, inserted a metal burr and clamped it with two hose clamps. I left it like that so that the woman could make sure it didn't leak for a few hours before refilling the hole and putting the pieces of turf back in place.
When I came in this evening there was a message saying that the repair had leaked---about a teaspoonful in several hours. Here's my question: will I improve the situation if I move the hose clamps out of the way and heat the ends of the pipe that overlap the burr with a heat gun before reclamping? I think I have a pretty good feel for how much I can tighten a hose clamp before it strips out, so just putting some more torque on the clamps probably won't do the trick. If the heat idea is a no-go, should I add another hose clamp to each end? Do something else? All ideas from your experience are welcome.
Thanks, Stan
Stan in Oly, WA
09-15-2007 10:16:44
 Re: Clamping black poly water supply line in reply to Stan in Oly, WA, 09-13-2007 21:15:41
Thanks everyone, your advice was even better than I had hoped. I went back yesterday morning and added a second hose clamp, reversed from the direction of the first one, to each end of the burr. I took along a tube of silicon aquarium caulk but left it and the receipt with the owner to use or return as she saw fit.
I also took a heat gun (unfortunately Russ's suggestion to use hot water arrived too late to help me this time) but an employee of the local water department who arrived on the scene shortly after I did suggested that I not use it if I hadn't done it before. He said that he always uses heat but that that type of poly goes from soft to crispy unexpectedly. I agreed that the risk/reward factor didn't support on-the-job-training on a correction that I personally wouldn't even have bothered with (the seepage had amounted to about 1 teaspoon of water in 23 hours---and seepage, in my experience, is often self-correcting from the minerals in the water.)
The woman was very aware that I had probably saved her about $350, not to mention the high likelihood that a plumber would have tried to frighten her into replacing the whole supply line (and very possibly viewed it as simply being "proactive" or, "better safe than sorry." That's an especially easy position to take when somebody else's money is involved.) No offence intended to any good and honest plumbers who might read this. There are certainly many decent, honest, reliable plumbers, mechanics, and even lawyers. There are also many who aren't. I speak from experience.
Thanks again, Stan
Oldmax
09-14-2007 19:36:01
There are two types of that pipe "Iron pipe size"& "Copper tube size" I don't like the fittings that use clamps. Ford & Muller Make compression fittings for both sizes they also make stab fittings you just push them togeather eather one works better than clamp type. Also use only 200 PSI pipe . will give less trouble.
Russ from MN
09-14-2007 17:47:40
I use two clamps with screws opposite as suggested, and I have my big thermos full of boiling water, slowly pour it over the pipe and fitting and assemble while hot. Sprinkler installers use torches with a fan flame, but hot water works for me.
CWL
09-14-2007 04:18:06
I've done a fair amount of work with that type of pipe over the years. I like to put two clamps on each end of the pipe with the screws on opposite sides. Like has been said already, make sure that the entire clamp is stainless and not just the band. I also use only brass barb fittings. In a pinch I will use the galvinized until I can get the brass. If going in with a new line always go with the heavier (160 psi I think) pipe because the exttra cost at the time of purchase is not that much.
TimV
09-14-2007 04:10:55
Stan: One other thing--if you're using clamps, you should be using two clamps per end of the fitting--one going one way and one going the other. Heating the joint slightly also seems to help--I use a heat gun, though a hair dryer will do in a pinch.
Tom in TN
09-14-2007 01:41:34
Stan,
I don't have a lot of experience with black plastic pipe, but I did install a large amount of it a few years ago. The plumbing supply house where I bought the pipe sold me some special splices that I used to join the coils of pipe to each other. The splices consisted of two large nuts, two rubber compression rings, and a center piece that joined the two pieces of pipe together. When the nuts were tightened onto the center piece, the rubber compression rings were compressed, and a water tight seal was made.
If you have a good plumbing supply house near by, you might ask them what they recommend for joining rolls of black plastic line.
Good luck,
Tom in TN
NC Wayne
09-13-2007 22:41:58
I"ve always heated the line a little to soften it before slipping it over the barbed fitting. Then while it"s still warm and a little soft tighten the clamp. I"ve never had one leak on me. One thing to watch for, especially since it"s a buried line, is to make sure the clamp your using is solid stainless and not just a stainless band with a steel screw.
old
09-13-2007 22:04:11
I use the stuff a lot on my place. What I do it turn off the water, then where ever I have a splice I take silicone and put it on the fittings. Clamp it down and let it sit an hour or so. Turn on the water and so far never had a leak.
135 Fan
09-13-2007 21:58:03
Stan, you could buy some of the wide European type clamps (T-bolts) used for hydraulic suction lines. They use a bolt that sucks them tight and can be tightened much more than regular hose clamps and don't chew up the hose like regular hose clamps can if over tightened. I think they are stainless steel as well. Dave
