Tool Talk Discussion Forum
Spot Welder Questions
Kerwin
09-10-2007 07:16:42
Just looking for some info on spot welders. I have some projects that require spot welds, and wanted to see if it was cost effective to buy one rather than have it done elsewhere.
Are the harbor freight spot welders any good? I see that they have both a 110V and 220V. Both are the same price. For size/usage, does it make sense to go with the 220V?
Is there an attachment for spot welding using an AC stick welder? Thought that I'd heard of this, but don't know particulars.
Any other thoughts, suggestions? Thanks for the help.
Dick L
09-13-2007 12:22:12
 Re: Spot Welder Questions in reply to Kerwin, 09-10-2007 07:16:42
I have a Hobart 110V and I like it. I dont use it much but I have good luck on all my projects that I have used it on.
third party image
third party image
third party image
circus
09-11-2007 20:41:11
Have a limco spot welder where two hand held electrodes are used for two welds at a time. It sucks. For better reliablity and appearance punch a hole in one layer of metal and fill with a mig welder. A hand tool that looks like a giant paper punch makes it a breeze.
135 Fan
09-10-2007 21:51:46
A lot of MIG welders have optional spot welding timers which might give you a more versatile machine. Miller makes good spot welders but they are pricey. I would think it's the same as with welders. You get what you pay for. Dave
Kerwin
09-11-2007 07:35:34
 Re: Spot Welder Questions in reply to 135 Fan, 09-10-2007 21:51:46
How does it work with a MIG welder? Do you need special tips/attachments? I have an older Lincoln 110V MIG welder (SP-85).
135 Fan
09-12-2007 20:23:53
 Re: Spot Welder Questions in reply to Kerwin, 09-11-2007 07:35:34
From what I've seen the only difference is the nozzle has half circle cut outs on the sides. I think they stick out a little more from the contact tip and rest on the plate. The cut-outs on the nozzle I think allow the gas from welding to escape so you don't get porosity in the weld. A good welding supply would be able to show you. Dave
dobber
09-10-2007 08:27:40
I had one of the sliding gun ones for a stick welder and it worked a few times till got too hot and then melted into a piece of junk. You'll get what you pay for. Pay to have it done or pay to buy a professional type spot welder. You could always resell it later right?
NTP
09-10-2007 13:01:24
 Re: Spot Welder Questions in reply to dobber, 09-10-2007 08:27:40
I have both the 120 and the 220 from Harbor Freight and and have been satisfied with them. The 220 will weld a little heavier material. For what it's worth, both the HF and the Hobart spot welders are identical, right down to the parts diagrams. In fact, they both use the same part numbers. The only difference I coud spot, was the stickers they apply to the units before they sell them. If you decide to buy the HF, be sure to purchase extra tips, as ALL spot welders require dressing of the tips from normal use.
Stan in Oly, WA
09-10-2007 16:49:34
 Re: Spot Welder Questions in reply to NTP, 09-10-2007 13:01:24
Hi NTP,
I inherited an unused H/F 230 volt spot welder earlier this year. Made in Armenia---that's a first for me. It came w/o the manual. I know I can get the manual from H/F online, but I've found the manuals that come with their tools to be virtually useless anyway. So I thought I'd ask you instead. What are the limits of the welder, thickness of metal, etc. Is there anything else about it you've learned that I would benefit by not having to find out the hard way?
Thanks in advance, Stan
