Hi Bob, I cut and sold part time for years as a young man (college years) and split hundreds of cords by hand. (Until I got a real job so I could afford a hydraulic splitter :) Definitely a maul, not an axe. I recommend looking for a 7 lb maul - hard to find but I have found they are just the right weight. I've used 6 pounders (too light for power) and 8 pounders (just a bit to heavy causing undue fatique). Also, make sure it is a simple maul shape - like a slege that is a bit longer and comes to a point on one end of the head. AVOID mauls that have a narrow blade-like shape on the wedge side of the head - they do nothing but get stuck in the wood. In my opinion a wood handle is the only way to go - just need to practice your aim (Bob, let the force be with you :) AVOID the 12 lb plus "Splitting bomb", "Super Maul" type. You'll need a nap after splitting a few pieces. Two or three wedges are a good idea, but have a sledge to drive them. I broke a maul head driving wedges. Split with the logs standing on the ground, NOT on a raised spliting block. That is an extra 18-inches of nearly free momentum you are giving up by having the log raised off the ground. Plus, it is a lot more work to pick up each log to put it on the block (often a two-hand operation) than it is to just stand it on the ground (usually a one-hand operation). Unless the wood is very stubborn, most of the work splitting by hand is standing up the logs and pieces of logs after each time you swing the maul. Now when I split by hand I stand up on the order of 6 to 10 logs side-by-side and bind them together fairly tightly by one wrap of rope and using a cinch knot. As you split, the pieces just stay stood up, and away you go. I use this technique now-a-days to split my kindling, take no time at all. The only issue here is it does increase the chance of breaking the maul handle when you are swinging at "inside" pieces. To avoid breakage I lift the maul handle up toward verticle just as the mauls is hitting the piece. Good luck.
