Tool Talk Discussion Forum
What do I try next
Jrry
09-09-2007 12:23:43
I have a Sears riding mower with a 20 HP Kholer engine. The selnoid had been acting up for a good while. About a month ago the mower would not crank. I thought the selnoid went completely bad. I have purchaed a new starter with selnoid and installed it but still no go. I have power to the starter and power to the selnoid through the switch. If I have power to both then a safety mechanism should not be causing the problem should it? What to try next?
Kent in KC
09-14-2007 10:14:56
 Re: What do I try next in reply to Jrry, 09-09-2007 12:23:43
Remember to always eliminate the simple, cheap things first. On this kind of a problem it is often just 'less than clean' battery connections. It is important that the cable clamps and battery posts are scraped or wire brushed to a bright shine. A dull gray can camoflage resistant corrosion to block just enough juice that it won't kick over, or if it does turn over, not enough amperage to the coil to fire.
Old battery cables can also have corrosion inside the insulation of the cable itself that will shunt current. Cut back some of the sheath and, if you see green or grey, replace them.
Tend to the connections at all points, including engine to chassis ground straps. Nice bright, tight connections will assure you're getting the juice you need. Good luck.
suptscottyb
09-10-2007 21:07:11
I had an old craftsman that used to do that. The cause was rats chewing on the wires. They got behind the battery and the dash. Then they did it again on the new mower...good luck. p.s. finally taped decon to the wire harness and dorn if the chewin" didn"t stop.....
The REAL Hal/WA
09-09-2007 20:37:29
I had to replace the ignition switch on my ancient White riding lawn mower with BS engine. It just wouldn't work any more and was easy to replace. I had long before wired around the no longer available interlock switches, since the dust had ruined them. Since no one else ever ran that lawn mower, I thought it would be OK to go without the safety features. And it was. I finally retired the White after the engine grenaded and after I had welded up the mower deck so many times. It served me well.
I would suggest studying the circuit diagram carefully to see if there is something else that could be making it not crank. A stuck safety switch would be my first suspicion, but I have never worked on a Kohler powered mower, so it could be different. Most are easy enough to wire around to test if they are not making proper contact. And obviously, you have tried a different battery, haven't you. After a while, they lose cranking power. Good luck!
AL 2
09-09-2007 19:24:25
I had a similar problem on two Kawasaki engines. One in a JD and one in a Wheel Horse. I think the problem was that the voltage was being drained by all the safety switches and 'old age'. John Deere sell a capacitor for less than $20.00 that bolts on to the engine shroud and has one one wire to connect to the solenoid. The problem hasn't occurred since in four years. Before I found this out we replaced the starter, solenoid and battery in the Wheel Horse. I called quite a few JD dealers before one told me the remedy.
Al
Vally Farm
09-09-2007 13:25:54
Father has a Craftsman with a 25 hp b/s in it. If you have to push the brake down to start, that is where I would look first. Pull the battery box and mounting plate. You will be able to see the switch on the rt side. When you step on the brake it pushes on a switch to allow the engine to start, also to turn the mower deck off if it is running. In theory (I neither recommend nor condone this) if you were to just connect the white wires that go to the switch it would over ride the problem. Father has had problems for quite a while with this before I took a look at it. Mike third party image
Bob
09-09-2007 12:32:55
Check to make sure the engine is grounded to the mower chassis.
If the battery ground is to the chassis, then a GOOD ground is needed between the engine and the chassis. Rust and corrosion, and/or loose engine mounting bolts can cause problems.
If that's all OK, check the voltage (Key turned to "START") at the little terminal on the solenoid, referenced to the metal case of the solenoid.
If poor safety switches, poor connections, and possibly a bad ignition switch all add up, you can have SOME voltage at the solenoid, but not enough to make the magnetism needed to "pull it in".
Ron in Nebr
09-10-2007 22:39:58
 Re: What do I try next in reply to Bob, 09-09-2007 12:32:55
Dont forget that if there's power from the battery getting to the solenoid, and also power from the switch getting to the small terminal on the solenoid, the solenoid itself still needs a proper ground in order to function. Solenoids "usually" ground through where they're bolted on. Maybe there's corrosion underneath it not letting it ground?
