Tool Talk Discussion Forum
weight oil in cherokee?
RobMD
09-07-2007 15:40:58
Picked up a cherokee without an owners manual. Anyone know the factory weight and how much of oil you put in it?
10-30? 6 quarts?
thanks
J.C.in AZ.
09-09-2007 10:49:05
 Re: weight oil in cherokee? in reply to RobMD, 09-07-2007 15:40:58
Got an '85 with a Chev 2.8 V6,use Quaker State 20W50 with a Ph8 Fram Filter takes 5.5 Qts per change.Need 20W50 here in the Desert in summer or all year round for that matter.
MeAnthony
09-08-2007 06:57:21
I run 10w30 in mine. Takes about 6 1/2 quarts with the 1-quart size filter. In Fram, PH3600, PH3614, PH16, PH34 and PH8A all have the same thread and gasket dimensions, just different outside dimensions.
Hope this helps.
Anthony
RobMD
09-07-2007 19:12:22
thanks a lot fellers, it is the 4.0-6
rodgernbama
09-07-2007 18:40:40
I've got a 2001 with 4.0L engine. It takes 6 quarts w/filter 10W30.
deerhound
09-07-2007 18:25:24
I have a 93 4.0L and 10w-30 is the specified oil in the manual. 6 quarts with a filter.
Dale
Red Dave
09-07-2007 15:58:57
You didn't say what engine is in yours, but I have a '90 with a 4.0 liter 6 cylinder. I usually use 10-30 or 10-40. Mine needs 6 quarts with a filter change.
