Tool Talk Discussion Forum
Where to buy injector bolts?
Jrry
09-07-2007 06:48:25
I need a couple of the injector bolts that have the hole in them. One is for the return fuel line and the other is one coming out of the injector pump (overflow I guess). The injector pump is a Simms on a Fordson Power Major if that matters. Are these available at auto parts store. Are they a standard size?
Joe M(GA)
09-08-2007 05:54:44
 Re: Where to buy injector bolts? in reply to Jrry, 09-07-2007 06:48:25
go to this site below
click on parts & service
click parts look up
use "major" as the model and go down to the fuel section
Bison
09-07-2007 20:36:47
Take a stock bolt with the right tread, and drill the holes in them, no big deal and done quicker than running all over the place to find one.
My two cents worth
Bob
09-07-2007 08:08:33
Apparently, you need bolts for "banjo" fittings.
Your best bet would be a local diesel injection repair shop, or POSSIBLY NH, if they are still a good part number.
If you don't find some, post back. I have a parts tractor I'd scarf a couple off of for you, if needed.
Jrry
09-07-2007 09:18:27
 Re: Where to buy injector bolts? in reply to Bob, 09-07-2007 08:08:33
I called the NH but they said they would need the old one to look it up. If I had the old one I wouldn't need a new one. I will try the injector repair place later today. thanks for the info.
Bob
09-07-2007 11:02:38
 Re: Where to buy injector bolts? in reply to Jrry, 09-07-2007 09:18:27
I have a Ford Major parts catalog. If you tell me SPECIFICALLY which bolts you need, I'll get some part numbers.
As I understood, you need the one the attaches the "drip tube" to the injection pump, and one of the bolts that ataches the banjo return line to the top of one of the injectors???
Jrry
09-07-2007 11:21:06
 Re: Where to buy injector bolts? in reply to Bob, 09-07-2007 11:02:38
Bob, I need the one that attaches the drip tube to the injector pump and the one that attaches the return line to the block on the rear of the block just below the valve cover. thanks
Jon Hagen
09-07-2007 11:54:51
 Re: Where to buy injector bolts? in reply to Jrry, 09-07-2007 11:21:06
Guys, might the banjo bolts from a Perkins diesel(354) that were so popular in the Massey and white combines work ? I remember them having the banjo fitting on top of every injector for the return line and on the Simms ?? injection pump.
