Tool Talk Discussion Forum
Soldering iron question.
Mike in Ohio
08-31-2007 06:17:20
I've done thousands of copper pipe joints with a torch but never soldered wire with any luck. Do you heat the wire then apply the solder like you would with pipe, or do you use the iron to melt the solder onto wire and connector? I think I will finally get around to rewiring my trailer this weekend and might try it this way with the heat melting type of insulation on the connectors. Thanks alot for your help, Mike
Mike in Ohio
09-01-2007 05:34:22
 Re: Soldering iron question. in reply to Mike in Ohio, 08-31-2007 06:17:20
Thanks alot to everybody. Now I have to see what wattage my iron is and what kind of solder I have before the usual Sat. morning trip to town. Thanks again. Mike
Stumpalump
09-01-2007 05:09:32
Two tricks. Put the iron on the wire. Then put the solder on the iron at the junction with the wire. This molten solder will transfer the heat to the wire better than the iron alone. Give it a second then hit the whole thing with solder. Next trick is that you must allow it to cool without moving. If your work is barely twisted or just touching a board the molten solder acks like a lubricanr making it fall apart. You need a solid dry conection first and then you must hold very still till it cools. A little practice is all you need. One more tidbit if it wasn't covered is that a good solder joint is shiny. A dull joint is cold and you should remelt the mess and apply some fresh solder.
Fawteen
08-31-2007 17:46:16
I was a Navy Electronics Technician for 22 years. In that time, I was certified to do miniature and microminiature repair on multi-layer circuit boards. Part of the certification requires excavating 3 layers down into a board to repair a broken foil run and then repairing your way back out, with inspections at every step. I was also a certified instructor for miniature soldering.
I think I'm safe in saying I know a little bit about electronic soldering.
Short version: Wavrider has it exactly right. The only thing I'd add is that the less solder you can use, the better. The minimum amount that will establish a fillet between the surfaces to be joined is ideal.
Most people subscribe to "the bigger the blob, the better the job" theory. All that does is hide imperfections that will come back to haunt you later.
mjbrown
08-31-2007 10:04:34
Lots of good advice. If you can do pipe you will be able to do wire with a little practice. My advice has to do with the wireing. Use a ground wire in the new wire harness instead of grounding through the trailer frame. Grounding through the frame invites poor grounding due to corrosion at any and all wire to frame connections due to dissimilar metals+moisture and current.
Wavrider
08-31-2007 08:49:31
Soldering or "tinning" a wire.
The best results will be achieved of the wire is cleaned first. regular isopropyl alcohol will work.
Using either a liquid or paste flux, flux the wires to be tinned. This will remove any impurities in the solder joint.
Clean the tip of your soldering iron with a damp rag. then apply flux to the tip of your iron to clen it. Put a little bit of solder on the tip oif your iron. you will use this as a heat bridge to more efficielntly transfer the heat from the iron to your wires.
Once your wires is hot enough you may now apply the solder (60/40 is best for electricl work solid no rosin core) to your bare fluxed wires and you wil se the solder flow into your strands.
You can use a heat shield, it is like a little metal clip purchased at radio shack, or an old tie clip will work if it is metal, will prevent the wire from melting the insulation jusy clip it on at the wire where it meets the insulation.
Once you have the two wires tinned you will ned to clean them again, flux is corrosive.
Either use a lap solder joint where you lay the two wires side by side or if you need physical strength use a hook joint, sort fo like two fish hooks linked together.
Same method applies to soldering the joint as is used in tinning, solder bridge on tip of iron, pleanty of flux to kep the joint clean and free of impurities.
Do not forget to put the heat shrink on the wire first before you solder if you are going to seal the splice.
Clean the solder joint after it cools to avoid any corrosion from the flux used while soldering.
It may take a few tries to get the tinning process down so practice on some sparew wire you may have laying around.
I apologize about any spelling errors, trying to eat lunch here at work and type at the same time.
circus
08-31-2007 07:43:26
Clean & flux wire. Melt solder onto iron to have a hanging drop. Touch the wire with the drop The drop transfers the heat faster and wicks onto wire without insulation damage. To join wires presolder ends with adequate amounts, place together, then reheat. beautiful
TimV
08-31-2007 07:12:24
Mike: any type of soldering is done by heating the substrate (thing to be soldered) and then using this heat to melt the solder. Doing it by melting the solder onto the substrate will result in balls of solder just barely sticking to the substrate and not effectively joining the wires. Another note-make sure to use solder specially made for electrical work--it's not acid-cored (acid-cored solder will cause corrosion in the joint) and is usually smaller in diameter than "regular" solder.
Bill-KCKs
08-31-2007 07:10:22
Heat the connection, then apply solder. The wires should suck up the solder.
If the soldered connection looks dull and grainy, you probably didn't use enough heat.
Use rosin core solder, no acid core for wiring.
The wire needs to be clean, obviously.
Use a big enough iron, especially if soldering outdoors in a breeze. 35-50 Watts, unless you're outside in a breeze, then drag out the Weller gun or the 100-watt American Beauty.
Greg_Ky
08-31-2007 07:07:19
On electrical connections use 60/40 rosin core solder. Heat the wire / connector and touch solder to it.
Ebbsspeed
08-31-2007 07:05:17
Same as pipe, you need to heat the wire being soldered, not the solder.
Old Timer in Ohio
08-31-2007 06:33:04
What works best for me is to apply the iron to the wire. Then just touch the solder to the heated wire.
Don't apply heat any longer than you
have to,as you can melt the insulation.
Lots of luck Bob
God Bless
