Tool Talk Discussion Forum
bobcat 743b
corey H
08-30-2007 16:31:17
Front rt wheel drives fwd and rev. Back rt wheel does nothing,fluid leaking on inside wheel and tire. Any ideas??
135 Fan
09-01-2007 00:59:58
 Re: bobcat 743b in reply to corey H, 08-30-2007 16:31:17
Leaking axle seal for the oil. Bobcats use a 2 chain bow-tie assembly on the drive motor. The back chain has broke or came off somehow or the sprocket has a problem. Maybe something seized but I doubt it. There should be cover to get at the chain case. It will have oil in it. Dave
oldrustycars
08-30-2007 17:03:34
Not familiar with this model, but most skid steers have chains to drive the front and rear wheels. If one breaks, the other 3 keep driving, often forcing that big chain where it shouldn't go. You likely have torn up the bearings on the axle stub. Generally, a not complicated repair, just nuts and bolts.
corey H
08-30-2007 17:11:14
 Re: bobcat 743b in reply to oldrustycars, 08-30-2007 17:03:34
Thanks for info any idea where to start. Very mechanicaly inclined just never worked on one before
