Tool Talk Discussion Forum
Topic: solder gun recommendations Update
Hobo,NC
08-30-2007 05:07:07
Update to a reply I made on Topic: solder gun recommendations
I posted a pix, got a reply that I could buy new covers for it. I looked up their web side and sent a email, got a reply first thing next morning, got a call late yesterday.
They wanted to make sure I could find the replacement parts, gave a me a web site and a distributor number to call, confirmed the #8200RH included both left and right hand sides. The call was left on my answering machine @ 5.45, guess I was feed"n my belly @ that time. They left me a direct # and name if I had any problems. How bout that sheet, a company that has real folks to talk to, Makes a call when it was not asked for. A First class operation for sure.
Stumpalump
09-01-2007 05:18:06
 Re: Topic: solder gun recommendations Update in reply to Hobo,NC, 08-30-2007 05:07:07
Do just use a piece of house wire for a tip? Thats a good trick. I have found that you need to remove the tip and sand the connection once in a while, Some tips are just better than others for some reason. Is that tip just a loop of copper wire?
Hobo,NC
09-01-2007 06:42:05
 Re: Topic: solder gun recommendations Update in reply to Stumpalump, 09-01-2007 05:18:06
Yes, if you go in the side you can use a bigger wire, if from thru the nuts you have to use a smaller wire
soundguy
08-30-2007 22:30:35
Better make an entry into your diary.. service like that is on it's way out in this day and age.
Soundguy
