Tool Talk Discussion Forum
rusted steel wheels
bts
08-29-2007 03:55:25
I'd like to rebuild an old steel wagon. The wheels are heavy duty with tires about 5 in. wide. Problem is the spokes and tires are about rusted through where it sat in the dirt.Does anyone know a good way to repair them?
old art
08-29-2007 19:13:27
 Re: rusted steel wheels in reply to bts, 08-29-2007 03:55:25
i helped myB.I.L.rebuild a36 JD A the front wheels were 16'' spoke wheels bent and bad rims sent out to some one in IA they rerimed them and straitened the spokes looked like factory . go to the JD board or Green machine magisen.for where to find him. ( B.I.L.cant help you died 2 days after we finished the restore job.realy miss him. )
glennster
08-29-2007 07:56:09
if you are handy at metal work, you can get some old car rims close to what you have, and either cut a section out and weld it to the bad rim, or if they are spoke wheels, cut the center hub out of the donor wheel, and then tranfer the hub from the spoke wheel to the donor outside. find the diameter of the spokes, ie-1/2 inch rod, and get cold rolled steel rounds and fabricate new spokes. re lace the wheel and then true it up.
JoeK(WI)
08-29-2007 10:04:03
 Re: rusted steel wheels in reply to glennster, 08-29-2007 07:56:09
Steel fabrication shop aways from here will roll up to 1/4"thick by?? flat rings(like barrel hoops)for a price...Elsewise if the metal"tires" need replacing...maybe"slices" off a large pipe?
What diameter are your wheels?
