Tool Talk Discussion Forum
Insulating An Overhead Door
Glenn FitzGeral
08-27-2007 20:16:30
I'm insulating the 9x7 torsion spring overhead recessed wooden door on my shop with styrofoam. I'd like to cover the foam with 1/8" wood paneling for protection as well as a more finished look. Will the lift system handle the added weight? Obviously I'd have to increase the torsion spring tension.
Thank you,
Glenn FitzGerald
Ted In NE OH
08-28-2007 16:08:04
 Re: Insulating An Overhead Door in reply to Glenn FitzGerald, 08-27-2007 20:16:30
It is the fumes fron a fire near styrofoam that kill you.
Jim Broughton
08-27-2007 20:28:41
Glenn: Go to your lumber yard and purchase the "smooth-faced" styrofoam; it usually comes either light blue or pink in color.2X8 or 4X8 sheets,whichever is handiest for you to handle. It cuts easily on your table saw with a fine tooth blade. Next, get your local metal shop to make you "Z" moulding, 8 ft. long to run on each section of your door. Paint the styrofoam with LATEX primer (1-side) and glue to your door with liquid nails; screw or nail the light "z" moulding on the top and bottom horizontal edges of your door. Finish the whole thing in a good latex enamel or a regular oil-based enamel to complete the job !! Works like a charm !!
Cheers !! Jim B.
Dave Sherburne NY
08-30-2007 09:01:04
 Re: Insulating An Overhead Door in reply to Jim Broughton, 08-27-2007 20:28:41
That Blue or Pink stuff is not styrofoam, it
is Polystyrene. It has more insulating value, will
stand up to ground contact, but not weedeaters,
and breaks with a pop when you bend it. It is what
should be used under concrete floors with heat tubes
in them. It is just what you need to insulate the
door.
dan hill
08-28-2007 03:53:54
You should make sure that any foam insulation you use is fire resistant.One of my gunsmith books has info on foam insulation being ignited by a hot chip from a metal lathe.
Mattlt
08-28-2007 05:55:38
 Re: Insulating An Overhead Door in reply to dan hill, 08-28-2007 03:53:54
MOST (I say most) of the Styrofoam-type products now days will only sustain combustion while a flame is applied to them. Pull the flame away, and the fire goes out.
Obtain a sample of what you're going to use and test it out.
