Tool Talk Discussion Forum
Plugging Mirror Holes In Truck Doors
Glenn FitzGeral
08-26-2007 05:12:52
My '88 Chevy 3500 is in very good condition. While they work well, I would like to remove the big towing mirrors and install some smaller factory ones. Does someone make plugs for the 3 holes in each door? I do not want to weld the holes shut and do the necessary body work/repainting as I may want to put the mirrors back on again sometime.
Thank you,
Glenn F.
dan hill
08-27-2007 04:00:59
 Re: Plugging Mirror Holes In Truck Doors in reply to Glenn FitzGerald, 08-26-2007 05:12:52
Snap in plugs are used in electronic items,some are chromed.These plugs are used so adjustments can be made without taking the cabinet off the item.WHY
J.C.in AZ.
08-26-2007 13:10:50
Try some of those plugs they make for Electrical Panels. I have some out in the shop about 1/2" Dia. Some of them are small and might have a neat look when installed as Hole Plugs in your Door. You could paint them prior to installing them.
Goose
08-26-2007 06:21:34
I'm assuming this is a working truck and not a show truck. A simple option would be to put round headed bolts of some sort in the holes and use a little touch-up paint to paint the heads the same color as the background. Shouldn't look too bad.
rb/ct
08-26-2007 06:21:12
Also Loews and Home Depot, in plastic, black or white and in metal, chrome.
Ken Crisman
08-26-2007 05:40:09
Yes , plugs are available at some of the older auto parts stores or go online to autobody supplies & do a search .My brother in law had it done to the prestine 87 Bronco that he bought from my parents estate . Good luck & God bless, Ken
