Tool Talk Discussion Forum
Wet sandblasters
TimWafer
08-25-2007 11:09:24
Anyone have any experience with these sandblaster attachments for a pressure washer? I have one of the little pressure pot sandblasters along with a big diesel compressor but its still too slow, not to mention the dust. I also have a 4000-PSI pressure washer and was wondering how one of the wet blasters might work with that. What are the pros & cons?
Thanks
Tim
NE IA Dave
08-26-2007 15:29:50
 Re: Wet sandblasters in reply to TimWafer, 08-25-2007 11:09:24
I have I think five or six different sandblasters, and have had a wet one for twenty five years plus and I personaly think it's great. The thing to do is as soon as you get done just take a air hose and spray it dry. I have a large LP burner and a twenty pound tank that I use to heat selected items up afterwards so I can paint it faster. I usualy blast the item, then pull the feed tube out of the sand and wash the item down to remove all the excess sand. It is no different than any sand blaster, you will always find sand that you wish wasn't there. It doesn't differ either as you must use your head and not take aim at a few areas on a tractor. Your pressure washer is no different as there are places you can rip up or destroy using water only.
Richard G.
08-25-2007 18:26:54
Used one on a Case tractor one time.
Had to wash the entire engine and crankcase with a pressure washer to get all the sand out. You cannot seal up every opening and keep all the sand out.
Don"t do it. You will be sorry.
Richard
Dale B
08-25-2007 20:00:58
 Re: Wet sandblasters in reply to Richard G., 08-25-2007 18:26:54
I bought one from Northern Equip. 10 years ago to do an Oliver tractor. I removed the sheet metal and radiator. I carefully plugged and taped over the engine openings. The job came out great , no warping of the sheetmetal , and no dust!! It helps to set your sandbags up on a barrel to lessen the vacuum needed to pull the sand to the nozzel, You get more sand on the work that way. And keep the sand dry , all the way to the nozzel. A full face shield is a must..... .
mjbrown
08-25-2007 15:52:59
I have one I have used a number of times. I got it from Northern tool for around $60. They work best with a high capacity power washer like yours. The sand supply hose needs to be positioned so it is on top when you hold the spray wand. If it is underneath water gets down in it and gloms the sand and it won't flow into the water stream. Black Beauty sand flows best. Play sand tends to wad up in the siphon hose. Put the bag of sand in a smallish garbage pail. Don't open the bag and dump out the sand. Just jab the pick up through the bag into the sand. That helps keep the sand dry and clean. Last of all, cover up! I wear a tyvek suit with hood, boots, dust mask, goggles gloves and earplugs. The water and sand go everywhere but there is nothing I know of that strips a trailer faster or better.
oldrustycars
08-25-2007 12:36:17
I tried one once, it would have been quicker to let the paint fall off with age. Maybe I was using it wrong, or had a wrong size nozzle, but I just got frustrated and gave up. A 15 pound pot with a 100 cfm compressor worked way faster, I was blasting an old trailer.
NE IA Dave
08-26-2007 15:41:01
 Re: Wet sandblasters in reply to oldrustycars, 08-25-2007 12:36:17
oldrustycars, if you have any pressure washer in excess of 1,500# that thing should work great. I would suspect a chunk of clear plastic from your bag of sand lodged in your tube/ hose. I have let a few folks use mine and the never took care of it. Once it was full of rust and water in the nozzle, and another time they let the (VENT) hose sit in a puddle of water and it sucked water int the sand tube.
I personaly use a plastic 15 gallon barrel and just remove a small area big enough to let the assembly drop in from the top. Then I cover with a plastic garbage bag. I have done the plain bag thing, but mine always finds a wrinkle in the bag to stop it from going towards the bottom.
I also like the idea of not filling up with sand very often.
RMinVa.
08-25-2007 12:53:10
I have one for the pressure washer. I used it on the cattle trailer when I tore the floor out to remove the rust.I used 650 pounds of sand. I was well pleased with it. The water keeps the sand from floating around in the air. I also removed the paint up the walls about 2 ft. with the wet snadblast. The nozzle I used is ceramic. The main thing is keep the sand dry so it flows easy.
Once you get down to metal it needs to dry fast and get the primer on as fast as possible. Oxidation starts fast. I'm talking within an hour you'll see rust start because of the water. I found it(wet) to be a lot faster that dry snadblasting and cleaner too.
