Tool Talk Discussion Forum
Ignition Switch
Ted in NE OH
08-22-2007 19:38:19
I need an 3 position ignition Switch. Off-on -start. The switch needs a set cf closed contacts in the off positipn to ground the magneto. Would a garden tractor switch work or any suggestions welcome.
dobber
08-22-2007 22:37:07
 Re: Ignition Switch in reply to Ted in NE OH, 08-22-2007 19:38:19
Some of the ones other mentioned at auto supplies are the cheapie ones you want to avoid. Be sure it's the right kind of switch though because if you put voltage into the mag accidently you are going to fry it! For HD switches like that check with any Cole Hersee dealer. Most HD truck parts places sell Cole Hersee and they have a online catalog too. www.colehersee.com You can get keyed or lever type switches like that and yes even HD lawn mower switches. Lots of welders use the lever type switches.
Bob
08-22-2007 20:20:31
I have used several ignition switches for DEERE garden tractors for applications on larger tractors with mags.
The DEERE part number is AM102543, @ about $16.00.
You MAY find something cheaper at NAPA, though.
John T
08-22-2007 20:07:56
Your concept and idea is sound cuz those garden tractors ground out n kill a small engine ignition in OFF same as you need for a kill switch equipped magneto buttttt ttttt ttttt ttttt ttttt ttttt
Im unsure of the amps your starter solenoid might draw (assuming thats your set up) and those lawn mower switches are cheapies and arent rated any heavier then absolute necessary HOWEVER the typical garden variety car or tractor solenoid dont draw all that much current so theres a chance it will work NO WARRANTY LOL
Most auto stores carry those universal On/Off/Start generic general purpose ignition switches amd I bet they are higher current rated then a lawn mower switch so for no more then they cost Id opt for one of those over a lawn type myself ifffff fffff they have a ground/kill contact terminal option???? cuz those are designed to supply power to a coil n never heard of a magneto, so if not were back to the lawn switch I reckon..... ..... Head to Auto Zone or Advance Auto or Pep Boys or NAPA
John T
CENTAUR
08-22-2007 20:21:40
 Re: Ignition Switch in reply to John T, 08-22-2007 20:07:56
He can make a short lead to ground and turn that position into a kill mode.CENTAUR
Charles (in GA)
08-22-2007 20:03:19
Go to your NAPA store, they have universal switches like that.
Charles
