Stan, it sounds as if the footing is an older one or what have you, and should not be a problem if in reasonable shape and you tie it in with vertical and horizontal reinforcing bars. Rebar, you can drill and dowel in, using a hammer drill, make a larger hole diameter with a bigger bit, then drill close to the diameter of the bar, to hold it in place, kind of like a socket, use a product like Quikrete anchoring cement or other similar product made for that purpose, to install vertical reinforcing rod to existing. I prefer to freshen up the surface of old concrete by using a chipping hammer or similar to expose a new surface, then dowel in sufficiently to tie in the new and soak the existing before the pour. Not entirely necessry to chip off the surface of the old. You can also use an epoxy to bond old to new, might be overkill, but there is a product for it, have not done that in a long time, would have to research that further. If you want the 34" wall to really be tied in substantially, you would want to dowel in at least every 2 feet, #4 bar or slightly larger would be fine. I'd also have at least one horizontal bar overlapped and tied together, it sounds like you may have the reinforcing sufficient for the purpose, but now is the time if you have any doubts, or if you have spans with vertical bars too far apart. You stated the form is up already so I may be preaching to the choir here. Another thought comes to mind is drainage behind the wall, did you place sloped weeps, short sections of PVC through the form would suffice, backside to have perforated pipe, tied in with "tees" bed in clean crushed stone and cover with filter fabric, backfill with gravel. Use a hardware cloth type screen or other device to keep critters out. As far as a pump, make sure the concrete supplier can provide you with a pump mix design for a pump truck, your pump guy ought to have the specifics, on the big jobs, a pump mix design is always submitted for approval, along with the other conventional mix designs, so your supplier should have no problem there. If you have any doubts on the quality of the mix, get 4 test cylinders like what the testing labs use, pack each in 3 lifts (1/3 of the cylinder at a time), rod each lift 25 times, screed the top off on the last lift. You can have a test lab break the cylinders to confirm the compressive strength, but this is a little on the overkill side, if your supplier is reputable, there should be no worry about strength, but if you want to be absolutely sure, make sure the supplier knows the mix will be tested, keeps em honest, but like I said if you ask for a specific mix, it should be fine from a reputable supplier. If the bottom of the form has gaps, can you run a toe board on top of the footing at the base of the form ? You could shoot it in with a powder actuated fastener or just masonry nails ( wear good eye protection with both !) 1/4" should really not be a problem, make sure the water/cement ratio of the mix design is right, meaning you don't want a real loose mix, but now thinking that it is a pump mix, it may have to be that way, the aggregate is smaller in sieve size for it to flow in a pump and not clog, the mix design has to allow for it to work in the pump correctly. When they do a slump test of the material they place it in a mold on a flat surface, pull the mold off, and measure how far it settles hence "slump" it will sag more the looser it is, meaning water/cement ratio, more water in the mix. The water cement ratio also determines it's ultimate strength, if too much water is added on site to the mix, it will substatially weaken the compressive strength, it's not good to deviate too much from the design mix. A 1/4" gap, ought to clog up no problem. It may leak some fluid but not enough to concern me, the finish may reflect those gaps but at 1/4", and the condition of the existing being uneven, you have done the best you can do to narrow it to 1/4". The above is just some general information about concrete, if your supplier has a proven (used before) pump mix design, and your pump guy is experienced, it should be as simple as pouring it into the hopper and the gaps should not be an issue, try to seal them with toe boards if you can. What I'd be more concerned about for a blow out is the vertical and diagonal bracing you have in place if using lumber forms, not a form system, there is no overkill when it comes to bracing, 12" to 16" on center and each should be diagonally braced and staked, however you form it, bracing is very important each must be strong and properly secured. A concrete vibrator can and will blow out a form, especially if it is not braced properly. An example I can think of: I did a 6' to 8' high retaining wall pour at a friend of mines house, and he did not know much about these vibrators, I had extensive knowledge of them, but I kind of kept quiet about it, let him call the shots, he does lots of concrete slabs in his pool repair business, I was just there to help, he's a great friend, very lucky to have good friends like him. I brought the concrete vibrator, well it ended up that they filled the form to high to use it and being lumber forms, when I hit it with the vibrator, all the concrete settled at once, Yep I looked like a real idiot, it blew, I should have done what I knew to do, will explain that next. Well all was not lost, but because it was used when the form was getting full, the vibrator caused too much settling at once and it bulged and blew out. Well with everyone scratching there heads, I said well don't just stand there ( then I was a little p#ssed but knew we had to fix it ) get shovels on that blown out area, get that 1010 dozer over here and shove that form back, we corrected it and it was to be faced with stone anyway so it really was not a big deal.
The vibrator will settle the concrete uniformly and insure a better finish against the form, but do it in lifts, just run the tip in there and yank it out quickly, you'll see how it works, take some material and put it in a bucket loosely, hit it with the vibrator, watch how fast it settles, just hit it once quickly and keep it moving, you don't want to leave it in one spot while it's on, as you will settle the aggregate to the bottom. fill the form evenly by say 1/3 or so, place the tip quickly into the material and pull it out, move right along, place more material, follow the chute as it's poured, repeat until you get to the top of the form, if you wait to use one of these when the form is full, it will all settle at once, and it will put a tremendous amount of pressure against the form. Even with big pours on construction sites, they do about the same thing, settle it as you place it. When the drop is over 8'-0" they use a trunk to reduce the fall, and they settle it with a vibrator, but as they go along, not all at once. Other things, make sure any electrical for lighting, drainage or other items you may want has been considered, put your weeps in, conduit or what have you, make sure no braces extend above the form, makes it easier to finish, and soak the forms before you pour.
Sounds like you are ready, double check that bracing and add more if need be, tell us how it comes out, glad to be of any help !
