Tool Talk Discussion Forum
Hydraulic cylinder
Jiles
08-16-2007 06:04:24
Anyone know of a source for buying an electric hydraulic cylinder. I need a 12V dc motor, hydraulic pump and cylinder assembly. This will be used to lift a utility dump bed. I have done many searches but don't know exactly what to serch for.
supera3
08-16-2007 18:52:26
 Re: Hydraulic cylinder in reply to Jiles, 08-16-2007 06:04:24
Look for an old snowplow for a pickup or Jeep. They can be used for a lot of things, hay spear dump bed etc, if it snows put it back togather.
rockyhawaii
08-16-2007 14:34:28
Many tow trucks use the electric/hydraulic pump, and it's the same units the kids put in their cars to bounce them. You could try the car customizers or a towing/supply business.
DaveinIowa
08-16-2007 11:39:20
Sorry, forgot my e-mail address.
[email protected]
DaveinIowa
08-16-2007 11:37:46
I put a 1500 lb. 12 volt linear actuator on the dump box of my old cushman industrial truck. It works great! I got it it from Surpluscenter.com, seems to me it was around $120. But, their inventory changes alot, and I didn't see it in the latest catalog. I wanted a "walk-around" control so I made one out of a SPDT momentary switch (up/off/down) on a coiled cord. The actuator ran a little slow going through pendant cord so I installed a couple of relays to isloate the control from the power to the linear actuator. Much cheaper and simpler than hydraulics!
Email me and I'll send a couple photos
Dave
Tim (IA)
08-16-2007 09:36:17
I have thought about doing this for a small dump trailor using a scissor jack and a 12 volt motor (no hydraulics). Seems like I saw something like this for sale as a package recently.
john nelson
08-16-2007 09:19:21
Try looking for an old convertable car, many of them had them to retract the top. some of them were quite strong, usually had 2 cylinders. the motor and pump mounted under the seat usually.
John
alg
08-16-2007 09:13:59
try surpluscenter.com
JDB
08-16-2007 07:50:18
ANDCO actuators
sid3949
08-16-2007 07:49:23
try , Valley Mfg Waynesboro Pa. 17268 phone 800 233 5532
Ken Crisman
08-16-2007 07:05:43
Try NorthernTool.com
Don LC
08-16-2007 06:54:40
Look under Snow/Graders they use such a system..... .
TimV
08-16-2007 06:22:05
Jiles: if you're looking for all of this in a single unit, it might be a bit hard to come by. Typically the motor/pump unit is mounted remotely and plumbed to the cylinder. A typical unit is shown in the link below. They're usually called "power packs".
