Load Limits
Tim
06-11-2001 08:59:34
Hello,
AFter reading the previous story about the 11,000 pound doser and the F-150, I started thinking about my own situation.
I have a Dodge 2500 standard cab 2x4 with a 230hp Cummins Diesel pulling a 12k GVW gooseneck trailer. The trailer ways 3,000lb unloaded. Since the oper. manual says I can pull 10,000lbs, is it safe to assume the most I can put on the trailer is 7,000lbs?
I want to haul a JD B (3k) plus a JD A (4k) together this weekend, legally..
Thanks,
Tim in Az.
Ray,IN
06-12-2001 20:09:01
 Re: Load Limits in reply to Tim, 06-11-2001 08:59:34
I've got a '96 D2500HD w/Cummins, and my owners manual states the max. towing capacity is 18K lbs. I understand CA. trucks are rated lower though. If 10K were the max., most of the 3/4T trucks towing 5whl campers would be severely overwieght. Check with a Chrysler dealer and verify your max. towing capacity. The hitch weight is important too. The truck GVW and rear axle limits must be adhered to as well as the GCVWR.
OOPS! Ray,IN
06-12-2001 20:32:49
 Re: Re: Load Limits in reply to Ray,IN, 06-12-2001 20:09:01
I am wrong- 18K is the GCVWR, not the max. trailer weight. You are correct, 10.5K is the max. for the towed weight. I fell victum to the foot n mouth syndrome. Sorry,
Mark Kw
06-12-2001 13:08:05
Legally you need to check your state. It does not matter if your truck can safely handle trailer the weighs 70,000 pounds, if it ain't legal you're still liable for the ticket and fines.
Don't hold me to these numbers but I think on a class "C" (normal operators licence in most states) you are limited to a single vehicle rated >26,000 pounds and does not have air brakes or is a commercial passenger vehicle like a bus, towing a trailer >10,000 pounds.
Where you run into problems is how they read the laws. Some states will allow you to tow the trailer or drive the vehicle right to the limit of 10,000/26,000 pounds. Other states have read the cut off at 25,999 for the vehicle and 9,999 for the trailer.
Most states do not care if the trailer is rated higher than the limits of your license weight wise but if you load it over the limit, you are liable for the fine. Some states also require you to have a special class license for hauling equipment exceeding a certain pound rating and or self propelled equipment like tractors, loaders, ect.
I think you will be in safe working limits of both your truck and trailer but you do need to check with the state to ensure you'll be within the legal limits.
paul
06-12-2001 13:33:02
 Re: Re: Load Limits in reply to Mark Kw, 06-12-2001 13:08:05
I also don't really know, as Minnesota allows most anything to go as long as you are actively farming & hauling a farm load & under 26,000 gross.
But, I think the DOT on the interstates will be concerned with the gross weight that your pickup can handle, which should be stamped on the doorframe? This includes anything you have in the back of your pickup, you & any passengers, any trailer weight plus the load on the trailer, etc. etc.
--->Paul
Cal S
06-11-2001 18:20:55
Tim, that 10000 two weight applies to your bumper hitch. You will be fine and legal IMHO with two tractors totalling 7000 on a goose neck rated for twelve thousand.
