Tool Talk Discussion Forum
auto socket size rant!
JML755
08-14-2007 19:01:29
Went to auto store to get an ignition coil for my 2001 Pontiac Gr Prix. No big deal. $24. Clerk mentions the socket size might be 5.5mm for the 2 bolts holding it on. I have a full set of metric (short & long) and figured I probably had one. Anyway, turns out they WERE 5.5 and my sets had 4,5,6, etc. but no 5.5. Closest English wouldn't work. Called Sears and luckily they had a couple in stock. ($2.49). My complaint: Why couldn't the Pontiac engineer pick a size that is common to most tool sets? Makes no sense to me. Anybody have a logical reason for 5.5mm socket head? It took 5 minutes to change the coil and 20 minutes to run to Sears and back. I can imagine the frustration for a guy who lives 40 miles from a well stocked store.
Alan Y.
08-17-2007 14:11:26
 Re: auto socket size rant! in reply to JML755, 08-14-2007 19:01:29
In the smaller metric sizes, evidently the 1mm increment was too much. As already stated 5.5mm is fairly common these days. It's just that some people haven't come across it before, I guess. I often use a 5/16" interchangeably with an 8mm socket. I've used my 19/32 as a substitute for a 15mm before (the only time I ever use it) and 5/8 is very close to a 16mm. Of course, most know that 3/4" is the equivalent to 19mm. 13/16" can be used instead of 21mm and 7/8" is a loose fit for a 22mm. 1 1/16" is practically the same as a 27mm (lots of Nissan crankshaft bolts use 27mm). I don't often find 11/32" but I did find one on a kitchen appliance (range). Between 5mm and 27mm, the only metric size I've never come across is 25mm. I've found all the rest in various cars and pickups. I guess it exists somewhere. Anyone ever come across that size?
soundguy
08-16-2007 08:03:06
I'll bet a 6pt 7/32 socket would have worked..
Soundguy
buickanddeere
08-16-2007 06:41:02
 18mm hard to find too Re: auto socket size rant! in reply to JML755, 08-14-2007 19:01:29
I discovered when doing the brakes on my the truck the rear caliper assembly bolts to the axle housing with 18mm. My impact,regular & deep metric sets all jump from 17mm to 19mm. Fortunately one time while being in a meticulous mood. I purchased the 3/8 drive 18mm and the open/box wrench in 18mm. Now to order the rest of the missing sizes for my 1/2" drive sets. It took heating and beating to get those 18mm brake bolts out.
tech4
08-15-2007 09:11:33
The 80-90 Fords used a 5.5 mm 7/32 socket type wrench for the ignition module. A Craftsman 7/32 deep socket worked real well. I have also seen 5.5 mm in a lot of the Asia electronics.
big fred
08-15-2007 09:01:07
I've got a couple of 1/4 inch drive sets, both have 5.5 mm. I'm pretty surprised that you would have trouble finding one.
Mike M
08-15-2007 07:47:19
You gotta a clerk that was right on top of things ! Make sure you tell he was right and you were wrong !
JML755
08-16-2007 05:10:22
 Re: auto socket size rant! in reply to Mike M, 08-15-2007 07:47:19
Mike M, Yeah, I like this particular Advance Auto Parts Store because the clerks are more than just clerks. They're very helpful and friendly. Regarding the "7/32 is the same as 5.5mm" issue. When I tried the 7/32" socket, it "caught" at the corners, then slipped off as the socket turned. The difference is that the 7/32" is a 12-point and the 5.5mm I bought at Sears is a 6-point, so it fit the head better. My complete Crafstman (English) socket set was purchased in 1974. I've added to it over the years (metrics, multiples of common size sockets, etc), but the original ratchets still work well. I pity the pall bearers at my funeral. I told the wife to put the socket sets, my skis (still skiing on Rossignols I bought in 1976), etc. in the casket with me. Hopefully, that will be many years from now.
bradk
08-15-2007 07:12:52
7/32 is the same thing as 5.5mm.Most 1/4 drive sets has this size.
glennster
08-15-2007 06:31:32
we run into that at the body shop quite a bit. ford uses the 5.5 on suv wheelwell flares and mldgs too. then there is the whole crazy assortment of torx bits too, and then the tamper proof torx. the powerstroke diesel has special wrenches just to remove the fan asem. then the special tools to disconnect a/c and fuel lines. jeez it will drive you crazy.
JoeK(WI)
08-15-2007 05:47:01
I found out that I need a 16.5 sparkplug socket for a Honda now too..gotta sit down and see what that"matches" with in SAE.
As to the 5.5,I see SlapOn wants $15+ and no promise of even a kiss afterward :(
Nolan
08-15-2007 03:38:48
"Why couldn't the Pontiac engineer pick a size that is common to most tool sets?...Anybody have a logical reason for 5.5mm socket head?"
Because a 6mm was stronger than necessary, and 5mm wasn't strong enough. That 5.5mm bolt cost 1/10 a cent less than the 6mm, and over the production run of the cars, saved the manufacturer thousands of dollars.
5.5mm, and 5.3, 6.5, etc are all common in cheapie tool sets. I don't know the reason for that, but I've observed it numerous times.
Midwest redneck
08-15-2007 02:19:40
A 5.5 MM is .217" which is also a 7/32" size (7/32 is .218") Which may work for a 5.5MM. I talked to an old neighbor years ago who was the plant mang. of a bolt mfg company and he said that most of the bolts now are metric for cost savings. Like if you need a 1/2" bolt a 12Mm will work for the amount of thread needed but they save money on material because 12mm is .472" not .500. (its all about saving a buck at the car companies.)
wilko
08-14-2007 21:46:37
I have some old sockets in sizes like 19/32 and 25/32. What was that about!!??
CRUSADER
08-18-2007 07:25:04
 Re: auto socket size rant! in reply to wilko, 08-14-2007 21:46:37
I don't know about the 25/32, but 19/32 socket at one time was needed regularly on Ford engines for the connecting rods. From what was told to me by my father and some other older mechanics was that the clearance and strength was the reason for this. I have some of my fathers tools and keep these sockets around. From time to time I run accross the need for one.
Jim
oldfarmtractor
08-14-2007 21:21:36
I know what you mean. Sizes like 1/2" and 5/8 make sense. But what about 11/32 or 1 1/16.
I bet the quarter inch drive in metric has the same number of sockets as the USS.
Looks like another case where old people can"t change with the rest of the world.
Chris in MD
08-14-2007 20:00:22
i don't know, but i've seen bolt heads that say 5.5 or 8.8, i had no idea what the hell they meant until I found out there was a 5.5 mm socket!!!
5 and a half millimeters????? ???
isn't nominal size metric torture enough????? ????
Bob
08-14-2007 20:16:41
 Re: auto socket size rant! in reply to Chris in MD, 08-14-2007 20:00:22
The markings on the metric bolt heads designate STRENGTH, much like the "hash marks" on American bolt heads. NOTHING to do with the size of the socket needed.
Chris in MD
08-15-2007 08:19:57
 Re: auto socket size rant! in reply to Bob, 08-14-2007 20:16:41
oh. haha, go figure, the strength of the bolt is easier to read that the SAE heads.
msb
08-14-2007 19:34:56
Probably flunked the class on logic.
Bob
08-14-2007 19:11:45
Why would they choose such an odd size? Because they CAN, I guess, not to mention the fact making it tougher to fix yourself makes it more likely you'll return to the "stealer" for service work!
dan hill
08-21-2007 03:21:03
 Re: auto socket size rant! in reply to Bob, 08-14-2007 19:11:45
My 96 Ford truck has spline head bolts on the U joints.12 point 12 mm fits.I had trouble finding a 1/2 drive socket in that size.
