Tool Talk Discussion Forum
Drill bit sizes
joe leone
08-14-2007 07:57:40
I need to drill a hole that has a 2" dia. Is there anybody that makes a spade bit or anything I could use to drill a hole 2" dia and 1 1/2" deep.
2t2@ia
08-14-2007 20:55:37
 Re: Drill bit sizes in reply to joe leone, 08-14-2007 07:57:40
I have a cheap set of forstner bits 1/4 to 2 1/2, I think. I suppose they are Chinese made. I do not use them often, but they have preformed well for me. The whole set was under thirty dollars, as I remember. A drill press is the best way to use them though.
bva
08-14-2007 11:57:19
If I had to do this on the cheap I would get a set of those cheap hole saws like black and decker has. (cheap as inlow cost , not low quality) Cut the 2" hole, then cut 1 1/2" hole, Then cut 1" hole and then remove all excess with chisel. Use caution with forrester bits.
Jerry (NH)
08-14-2007 11:39:38
A forstner bit would be great if you can get your hands on one. And use a drill press if at all possible.
A 1-1/2 inch depth with a router may be possible, but may take multiple passes and increase the likliehood of a screw up. I've only heard about this; it would never happen to me. B^)
Alternatively, use a hole saw to drill all the way through your 1-1/2 and then glue the bottom piece on (or back on as you could slice it off to start with if you wanted). Depending on the wood color, grain, finish, and prep work the glue line might not be very noticeable. Or you could very purposefully give the two sections different finish, use different species, etc. and not worry about the glue line much at all.
Vern-MI
08-14-2007 08:17:38
Get a forstner bit in the 2" size. It will cut a two inch hole and leave a smooth bore and it won't chatter when you are drilling.
TimV
08-14-2007 08:12:49
Joe: What material are you drilling this in? That will be a large determining factor in which technology makes sense to use. Also, what is the application? A spade bit or hole saw will leave a pilot hole below the surface of the hole bottom, which may or may not be acceptable if you're drilling a blind hole.
joe leone
08-14-2007 09:56:30
 Re: Drill bit sizes in reply to TimV, 08-14-2007 08:12:49
I'm drilling in cedar and it's a hole to drop in a candle.I know I can get a forstner bit but they are expensive for a one time shot.
soundguy
08-14-2007 10:20:59
 Re: Drill bit sizes in reply to joe leone, 08-14-2007 09:56:30
Router it out.. Go slow.. wear goggles and watch your line..
Soundguy
TimV
08-14-2007 10:13:50
Joe: A forstner bit is probably your best option. If you don't want to buy one (about $50 for a decent one from a quick online search) I would think any local woodworker would be able to accomodate you for a nominal charge. I checked a few of my usual online sources and they only carry spade bits to 1 1/2". Based on past use of spade bits, this is probably at the high end of what you'd want to do with them anyway, as they typically cut pretty ragged. A bit more "outside the box" approach would be to do it in a milling machine with a 2" mill or fly cutter. Not exactly a production setup, but it should work for a one-off hole, especially as cedar cuts quite easily.
soundguy
08-14-2007 08:03:12
get a hole-saw attachment for your power drill.. it's usefull for making holes for door kob / latches.. deadbolts.. etc.
it uses a pilot bit with the saw cage around it.. You can buy 1 or many...
Other option is to drill a single hole.. say.. 3/8 witht he edge of the hole on an edge of the circle you need cut.. then jig saw it out.. or router it out.. or use a drillsaw.. wich is just a bit you chuck into a drillpress that will cut on the side of it's shank.. as well as plunge.. etc.
Soundguy
ray_woods
08-14-2007 09:14:21
 Re: Drill bit sizes in reply to soundguy, 08-14-2007 08:03:12
A hole saw or auger.
With the hole saw you may need to flip the part over if thats possible. A two inch hole is standard size for timber frame mortise so if you know a timber framer ask him.I have quite a few 2" auger bits laying around some are on T-handles. Reminds me check an antique store they may have some hanging on the walls for "decoration" purposes.
