Tool Talk Discussion Forum
welding question
jiskies2
08-13-2007 20:11:32
Well i went and dropped my olddd welder on the floor on the way to use it... now it doesn't seem to want to work is there a fuse or something simple i can check to get it going? don't use it more than a few times a year but it's nice to have.It's a Wards Power Kraft 230 (W40032 is the serial #) continuous amperage control. Or should i just go get another one? which one ? thanks, jeff
Stan in Oly, WA
08-13-2007 23:29:53
 Re: welding question in reply to jiskies2, 08-13-2007 20:11:32
Hi jiskies2,
Those are about the easiest welders there are to open up. About the only problem you can run into is if it has those little wheels you'll be tempted to pry one cap nut off the end of the axle to get the wheels out of the way. Don't do that. Just slip a wrench in beside the wheel to remove those sheet metal screws. The top and sides of the case are a single piece that slides up and off easily. Chances are the problem will be obvious. There isn't much to go wrong with one of those welders.
If my only welder was a Power Kraft and I only used it a few times a year, I wouldn't even think about getting something else. The ones I've used would sometimes change the amperage setting during use, but nothing that wasn't easy to fix with a bit of Yankee ingenuity. Guys my age often feel a sense of pride about being able to patch up a good tool and keep it in service. Younger guys seem to take more pride in being able to afford to replace tools at the first hint of a problem. Different times, different attitudes.
All the best, Stan
jiskies2
08-14-2007 03:05:35
 Re: welding question in reply to Stan in Oly, WA, 08-13-2007 23:29:53
k thanks for the info i'll give it a try... believe me i don't want to buy another one cause i can hardly use this one. wanted to weld a hay wagon tongue with it when i dumped it on it's side. ill let ya know how it turns out, thanks jeff
