Tool Talk Discussion Forum
Water Jet vs. Laser Cutting
Mopower
08-13-2007 10:00:46
Can anyone tell me which is cheaper for a plain simple shape in say 1 inch cold rolled steel? How about 3/16 inch aluminum?
ohio
08-14-2007 13:47:08
 Re: Water Jet vs. Laser Cutting in reply to Mopower, 08-13-2007 10:00:46
a flame cutting pantograph for the steel, or how about a doall bandsaw? plasma=high priced, reosonably accurate, thin material, very finicky.
plasma=less accurate than laser, thicker material, uncontrollable taper on thicker mat'l. cheaper, a little slower, a little more distortion.
wire edm=slooow. very accurate, does not impart MUCH stress, good for large sections and very hard steel. too slow for production on thin sections of mild steel or aluminum.
waterjet=? i don't know. only saw one piece done, a stripper pad for die, 1.250" crs. more expensive than roughing it out with a band saw, and cnc'ing the finish, or even me standing in front of a bandfile all day.
Joe(TX)
08-14-2007 05:08:38
Torch or plasma machines would be the cheapest. 1 in steel with a water jet would be pretty rough and slow, so therefore costly. Aluminum could be done with anything but the torch. Water jet is best for non metalic parts.
135 Fan
08-13-2007 17:37:43
Abrasive water jet cutting does an awesome job with no clean up. I imagine a laser does a similar job. As far as 1 inch mild steel an electric eye oxy/fuel torch would probably be the cheapest way to get it cut. This is how steel was cut and still is for tons of fab shops and OEM manufacturers. A good torch cut with a machine will produce a very fine cut that will rival any other method except for really intricate shapes and pieces. Not sure what's best for Aluminum. Dave
grub
08-13-2007 14:26:15
I would bet the water jet could cut the 1" material faster. How clean an edge you want controls the travel rate and thus the time per part. I would guess you would be about 12-18"/minute on 1" CRS. All the piercing to form the bolt holes would take time and the hole won't be perfect; you'll have a small ridge to remove w/ a die grinder prior to tapping.
The machine I am familiar w/ is in NW Oregon; if you are close I get get a quote for you.
Grub
nballen
08-13-2007 13:12:23
I don't have hard data to back this up, but I do work in the metal fabrication industry (locomotive manufacturing).
We use both plasma and laser cutting tables for most of our work - in-house and out-sourced.
The laser-cut parts have a very clean edge with a minimal burr at the edge.
The plasma machines are not even in the ball-park with the lasers for clean, precise parts. Also, the plasma flame will wander off the cut line a little. On thicker materials, say 1/4" and up, the plasma cut will not be exactly perpendicular to the flat surface. Where we run into problems with plasma cut parts is bolt-clearance holes, where the "design" size is correct, but the bottom of the hole is undersized due to the plasma "bending" through the material thickness.
From some "shop talk" a while back, the pump and nozzles for the water jet are very expensive; but I don't know how it compares to laser components.
Nathaniel
Pooh Bear
08-13-2007 12:18:26
Wow, I would have thought EDM was cheap.
I once worked in a shop that had an EDM cutter.
The thing was programmed using punch cards.
Didn't look like there was much to it.
Also worked in a shop that did laser cutting
of thin wood, and etching of glass and wood.
It was programmed using CAD and it
looked like it would be more costly.
Always wondered if water jet cutting
could be used with wood like a bandsaw.
Or would it be too wet for wood.
Pooh Bear
02XLT4X4
08-13-2007 12:27:03
 Re: Water Jet vs. Laser Cutting in reply to Pooh Bear, 08-13-2007 12:18:26
Actually they use waterjets to cut cupcakes, the water is going so fast there isn't much time to soak. They are a pretty incredable machine.
TimV
08-13-2007 11:53:59
Wire EDM will be far and away the most expensive method of the ones given, though also the most accurate. Nowadays, much of this work is done on a plasma-cutting table.
Pooh Bear
08-13-2007 11:45:31
And to cloud matters further
I'm gonna add EDM wire cutting to the mix.
Link
Pooh Bear
Mopower
08-13-2007 12:48:10
 Re: Water Jet vs. Laser Cutting in reply to Pooh Bear, 08-13-2007 11:45:31
Thanks for the input. The aerospace fixture shop I worked at used a wire EDM. Very neat, relatively simple set-up, expensve machine, and time consuming cut process. It worked awesome for holding .0002. I don't need much accuracy, but it would be nice to cut tappable holes or at least accurately placed pilate holes for tap drilling. I think laser, plasma, and water could all do that. But the cost? Who knows?
TimV
08-13-2007 13:00:11
 Re: Water Jet vs. Laser Cutting in reply to Mopower, 08-13-2007 12:48:10
MoPower: If that's what you're doing, you're probably better off with a CNC vertical milling machine, assuming you can fit the workpiece in the enclosure.
Mopower
08-13-2007 13:41:16
 Re: Water Jet vs. Laser Cutting in reply to TimV, 08-13-2007 13:00:11
I am cutting a larger quantity of circular rings out of a large (approx 4x8) CRS 1 inch plate and tapping a 9-bolt 3/4-16 UNF-2B tractor wheel pattern in them. Maybe 11 inch OD and 3-5 inch ID. I have the prints, CAD patterns, and plate necessary for the cut job. I could use pilate holes (or a template) to drill and tap the bolt pattern manualy. If I could tap a water cut hole, it would be less of my time, but MY time costs me nothing haha. Time to get quotes! Thanks for the input.
Bob - MI
08-14-2007 15:28:33
 Re: Water Jet vs. Laser Cutting in reply to Mopower, 08-13-2007 13:41:16
I have a source for waterjet cutting that's reasonable. Contrary to some beliefs, waterjet is used to cut metals as well as stone and you get good accuracy. You also get a cold cut with no heat affected zone.
Try the link.
Tell Mark Vanderwest the owner that Bob Johnson sent you. Great guy that works with simple to very exotic materials.
