Tool Talk Discussion Forum
Adjusting pto pulley
Bill420U
08-12-2007 10:52:40
My Kubota L225 has a Woods L59 belly mower mounted on it. The pto pulley wheel turns one large belt and must be aligned correctly with the lower pullies as they direct the belt to and from the mower. Well the pto pulley is out of line and the belt either slips off or turns around. How does one adjust the pto pulley on the pto shaft? I understand there are tapered inserts (sheaves?) between the pto shaft and the inside of the pulley wheel. The are 3 bolts securing a small plate to the pulley to hold the inserts in. There are two other threaded holes on this plate that I think are used to push against the pulley.
I'm afraid of breaking a bolt trying to loosen the pulley before I can align it.
Would somebody please describe the process of taking out these inserts or shims and then inserting them back and how these bolts are used to loosen and tighten.
Thanks.
Pete in MD
08-12-2007 11:10:08
 Re: Adjusting pto pulley in reply to Bill420U, 08-12-2007 10:52:40
Sounds like you have a Browning pully. Take out the 3 cap screws and screw 2 of them in the threaded holes. Tighten these 2 scews evenly once they snug up. This will push the pulley of the insert. Move the insert to where it needs to be, then put the pulley back on and reinsert the 3 screws in their original holes and tighten.
Bill420U
08-13-2007 15:27:56
 Re: Adjusting pto pulley in reply to Pete in MD, 08-12-2007 11:10:08
Thank you, Pete. It worked just as you described. I feel much better now.
