Tool Talk Discussion Forum
Injector cleaner additive-opinons
DCM
08-08-2007 10:29:43
Does it do any good on older hi-mile EFI gas engines and do you use it? Wondering. Dan
dan hill
08-12-2007 14:52:59
 Re: Injector cleaner additive-opinons in reply to DCM, 08-08-2007 10:29:43
These cleaners are a 50/50 mix of kerosene and alcohol.Make your own...
The Real Hal/WA
08-09-2007 14:32:31
I have a 96 Mazda Protege that works just fine if I use it 3 or 4 days a week. Unfortunately, especially in the summer, I don't use the nonairconditioned car very much. But if it sits unused for a couple of weeks, something seems to gum up in the fuel system. It has trouble raising RPMs from idle, and sometimes quits when I want it to take off. It has always started right back up, but the hesitation between pushing the gas pedal and the engine gaining speed is annoying. Luckily it is a stick shift, so I can deal with it usually by waiting for the RPMs to rise quite a bit before I engage the clutch.
Adding a bottle of the Chevron fuel injection cleaner sold at Costco seems to clear up the problem in 40 or 50 miles. I suspect that the fuel filter needs changing, but I haven't gotten to it yet. Probably will take getting stranded somewhere to make me do the work! But adding the bottle of cleaner is easy and has been effective for me so far. Fairly cheap too. Good luck!
Chris in MD
08-09-2007 09:12:21
I dump two bottles of whatever I can get in the tank and rub a rabbit's foot for good luck.
lucas boy
08-09-2007 07:42:46
i been useing injector clean,get it a napa in quart can, fixed a few cars ueing it.lucas
Red Dave
08-09-2007 06:18:42
I drive a lot of short trips and I do have trouble with injectors getting gummed up. I've tried STP, Chevron, Sea Foam and others, but the one that works best for me is Lucas. If you buy the quart and measure out the amount you need at a time, it is cheaper than the others too.
john *.?-!.* cub owner
08-08-2007 20:12:07
 Re: Injector cleaner additive-opinons in reply to Dale B, 08-08-2007 10:29:43
I have used Sea Foam a couple times a year in all my vehicles for several years, both carberated and fuel injected. It does a good job.
Bob
08-08-2007 22:02:52
 Re: Injector cleaner additive-opinons in reply to john *.?-!.* cub owner, 08-08-2007 20:12:07
Just GOTTA ask... What the HELL does *.?-!.* mean?
You must be REALLY bored to type all that for every post you make!
Jiles
08-08-2007 18:43:52
----Lucas---
big fred
08-08-2007 11:45:21
What's high mileage? I have 230K on my 5.0L F-150 and never run any cleaner additive thru it. I figure each injector has passed over 1800 gallons of gas in that time.
dhermesc
08-08-2007 11:21:43
Use Sea Foam, by far and away the best I've ever tried. I'e used Chem-12, Gum Out, STP and usually you couldn't tell the differance before and after.
bradk
08-08-2007 10:44:39
Older throttle-body injectors generally don't need to be cleaned.Newer or multi-port systems have smaller pintle nozzles requiring occasional cleaning.
GM has a real good cleaner that you pour into tank.I've used it a few times with great success.
