Tool Talk Discussion Forum
miller CP300 wire welder
Gary in Neb.
08-07-2007 11:46:42
i have a miller cp300 wire welder. it's a 3 phase unit. i'm moving to a different shop that does not have 3 phase and am wondering if anyone knows if i can somehow convert this thing to run on 220 single phase. i dont need to weld anything really to heavy so even if power drops off some wont be a big issue.
Stan in Oly, WA
08-07-2007 14:05:34
 Re: miller CP300 wire welder in reply to Gary in Neb., 08-07-2007 11:46:42
Hi Gary,
I've read on this forum that some 3-phase welders can be altered for single phase operation by the simple adjustment of internal connections. If that isn't a possibility you may be facing the necessity of buying or building a rotary phase convertor. There are whole forums on the net devoted to them.
Good luck, Stan
135 Fan
08-07-2007 23:17:24
 Re: miller CP300 wire welder in reply to Stan in Oly, WA, 08-07-2007 14:05:34
I would think you need a phase convertor. 3 phase will have a smoother output though. Dave
135 Fan
08-08-2007 22:02:57
 Re: miller CP300 wire welder in reply to 135 Fan, 08-07-2007 23:17:24
I should clarify. Getting a phase convertor so you can run a 3 phase machine will be a smoother arc than a single phase machine. Dave
