Tool Talk Discussion Forum
Tandem Trailer Axle Position
Glenn FitzGeral
08-02-2007 20:27:26
Last fall I cut the axles off my tandem trailer as someone had welded them too far forward, resulting in zero tongue weight. I plan on welding them on very soon.
That said, I understand one is to measure from the front of the bed to the end of the beaver tail and position the center of the axles 60% back from the front.
Does the same principle apply if one does not plan on loading the beaver tail? In my case it will be used for loading only as it is not designed for bearing a load.
Thank you, Glenn FitzGerald
Glenn FitzGerald
08-04-2007 18:58:01
 Re: Tandem Trailer Axle Position in reply to Glenn FitzGerald, 08-02-2007 20:27:26
Thanks for your responses. I went to the local trailer fab shop. The foreman there is confident I should mount them at 60% back even though my dove tail will seldom be bearing a load. I guess I've pestered enough people now. 60% back is where they'll be.
Glenn F.
mjbrown
08-03-2007 03:49:50
Everything I have read says 70-30% distribution. 70% from hitch to center of axels. That is about what ours are. Ones we have had that were 60-40 swayed more. The trade off is the farther back the axels the more the trailer cuts to the inside of corners.
135 Fan
08-02-2007 22:42:56
Generally they are about 2/3 of the way back. However, I have a friend that owns a custom trailer shop that uses a formula for figuring out exactly where to put them. I don't know the formula but it is based on tongue weight with what you will be mostly using the trailer for. Most couplers have a maximum tongue load rating for them. Dave
Steve Crum
08-02-2007 21:24:21
Stick to the 40% rear-60% front axle load calculated on the load bearing deck length. Bear in mind approx weight of the beavertail deck. This combination gives the best drivability and tracking without a lot of porposing. Just be careful not to exceed the trailer's or the tow vehicle's rated tounge weight.
