Tool Talk Discussion Forum
Wire for auto lift.
Steve-Maine
08-01-2007 14:27:09
I'm installing a car lift. I want to run a 75' cord so I can wheel lift outdoors sometimes. Will 10-3 work ok. It is 220 volt with 30 amp breaker. Thanks
Jerry F
08-02-2007 15:06:41
 Re: Wire for auto lift. in reply to Steve-Maine, 08-01-2007 14:27:09
here is a bunch of calculators for you. voltage drop included
Charles (in GA)
08-01-2007 19:36:10
My chart says that 10 gauge copper, loaded to 80% (that would be 24 amps) at 120 volt, is good for 64 ft. and still stay within the recommended 3% voltage drop. It also says the distance doubles on 240 volt, so you should be fine.
Charles
Steve-Maine
08-01-2007 19:52:38
 Re: Wire for auto lift. in reply to Charles (in GA), 08-01-2007 19:36:10
TO CHARLES.
Where did you find the chart? was it online? Thanks
Steve
Charles (in GA)
08-02-2007 20:25:56
 Re: Wire for auto lift. in reply to Steve-Maine, 08-01-2007 19:52:38
I think Jerry got you a good link there to the calculators. The chart I have is in a flip chart book called "Code Check Electrical" you find in Home Depot or Lowes on the book racks.
Charles
