Tool Talk Discussion Forum
What mower am I looking for
lenray
07-31-2007 08:59:43
Have a Bush Hog the real one that I use with the 756 IHC and have the zero turn commercial tank by cub cadet.
Looking for a mower in between these two that can be pulled by a say oliver 77 Ford 960 or a tractor in that size either 3 pt. or pull type.
Something in between the clean cutting zero turn and the somewhat rough Bush Hog. Thanks
hd6gtom
08-01-2007 18:30:08
 Re: What mower am I looking for in reply to lenray, 07-31-2007 08:59:43
Don't you bet flail mowers won't throw rocks,corn cobs etc at you. I have had them bouncing off both fenders,off the fuel tank and me. I will admit, with the flails, sharpened you can make a field look like a golf course.
Mike M
08-02-2007 07:53:19
 Re: What mower am I looking for in reply to hd6gtom, 08-01-2007 18:30:08
Which way did your rotor turn ? I'm wondering if they make them different ways. The ford's I ran turned in the direction you moved to pickup the tire tracks and stuff would go out the back.Never had anything go up near the tractor.
lenray
08-02-2007 07:13:57
What do you guys know about the MOTT flail mowers???
tHANKS FOR YOUR PREVIOUS THOUGHTS.
cj3b_jeep
07-31-2007 13:12:41
If I had to do it over again, it'd be a flail mower too. That way you can make grass look decent, but also cut the rough stuff, plus, it takes up less room than a brush hog.
CWL
07-31-2007 10:42:05
Flail mowers are hard to beat for what you are describing, but they are expensive.
Mike M
07-31-2007 11:47:23
 Re: What mower am I looking for in reply to CWL, 07-31-2007 10:42:05
New ones are $$ ,but used ones sell really cheap. I have had a couple of older Ford flails and they are built really well.
135 Fan
08-01-2007 18:27:56
 Re: What mower am I looking for in reply to Mike M, 07-31-2007 11:47:23
Ford flails have very light weight deck construction and will rust out. The blades also plug up and aren't self cleaning. A mott (alamo) uses less horsepower and has individual free swinging knives that are self cleaning. These were patented which may explain why only in the last little while other makes have a similar knive system. Alamo cost more but compare the construction. Alamo have way thicker deck material than a Ford. Fords will have all kinds of dents in the deck where alamos won't. Don't get me wrong, Ford flails work OK but wouldn't be my first choice. The biggest problem with a flail is changing blades (knives) because there is so many of them. If it is just for cutting a large lawn a finishing type rotary does a good job for less money and easier maintenance. Dave
135 Fan
07-31-2007 09:59:53
I have a Sicma 3 pt. finishing mower. You want rear discharge rather than side discharge. Finishing mowers have 4 wheels the mower rides on that also are adjustable for the height of cut. I like my mower because the deck is formed without square corners underneath, especially at the discharge, so grass won't get caught and plug it up. Finishing mowers have 3 blades and do a nice job on bigger lawns. Dave
mjbrown
07-31-2007 09:49:49
I've used a three point finish mower made by Farm King (Allied) for quite a few years now and it has been a good unit. It will handle stuff up to about the size of black berry canes just fine. It leaves a smooth looking lawn.
Mike M
07-31-2007 09:40:57
A 3pt model will be easier to find. You can go with a finish type grooming mower or a flail mower. The flail mower will do a decent job on lawns but can also handle heavy stuff and even real small trees and bushes. The flail type were used alot along hiways as they are not going to throw stuff far that you hit and also very little mower damage when you hit stuff as the knives are light and hang on a chain and swing back when hit.
