Tool Talk Discussion Forum
Sodering with pure lead
kez
07-30-2007 16:28:28
I clean my steel with sodering paste then I have the option of sodering with either a sodering mix or pure lead. My question which would stick to steel better. I'm only interested in filling in a small hole. Thank in advance for any information.
BuddyBear
08-01-2007 05:29:04
 Re: Sodering with pure lead in reply to kez, 07-30-2007 16:28:28
Just wondering why you want to use lead instead of body putty.
JOHN HARMON
07-31-2007 18:19:13
Back in the 50's I did a lot of Leading on different Custom Cars and after reading this Post I went out to the shop and looked in a Drawer of an old Rolling Tool Box I have not been near for a long time, and there was my assortment of Spools of Tinning Solder,Sticks of 20/80 Lead and all my Puddling and Wipe Down Tools just as I left them so long ago. My 1 1/2" X 12" Air Line, Stroke Sander is in there also. Lots of Grinding involved with Leading. Grind down the area to be leaded but don't burn it ,to bare metal.Get rid of all the "Rust". Tin the area with Pure solder by melting it on and then wiping it down quickly so all the bare metal is covered,puddle on the stick lead, don't get it Liquid, and move and smooth it with a paddle made from Oak dipped in Oil.Don't get any thing to hot. Very important to keep the Heat moving and keep the Lead plyable till it is pretty level and even all over the area. Let it cool and then start grinding and finish up with a Stroke Sander to level and burnish the area. Eastwoods has all the things you need.
Ken Crisman
07-30-2007 18:02:02
I started leading in repair patches on the tin of my tractors & its a real learning thing . Since I've taught myself how to do leading , I use very little body putty . I buy my quality materials from Eastwood . They have a website . Check it out . With the tinning flux they sell the lead sticks great . God bless, Ken
dan hill
07-30-2007 17:14:38
The melt point of pure lead is higher than solder .This old man has been using solder for 59 years.You need good quality solder to do good work.
GeneMO
07-30-2007 18:51:53
 Re: Sodering with pure lead in reply to dan hill, 07-30-2007 17:14:38
Do you use a soldering copper or just melt it on with a torch?
Then what rasp or file it down?
Thanks, Gene
dan hill
07-31-2007 03:18:18
 Re: Sodering with pure lead in reply to GeneMO, 07-30-2007 18:51:53
A torch tends to burn up the flux when soldering.A copper works better but you will have trouble finding one.There are special body file for lead.Leading body panels is a lost art.
Gerald J.
07-30-2007 20:15:53
 Re: Soldering with pure lead in reply to GeneMO, 07-30-2007 18:51:53
The advantage for most purposes that solder has over pure lead is that besides melting at a lower temperature the soft range (between solid and liquid) is smaller, smallest at 63/37 ratio. But the wide pasty range of lead lets you wipe it to shape, that's what plumbers used to do all the time, and what some body makers and repairers used years ago.
Gerald J.
