Tool Talk Discussion Forum
Soldering Plumbing
mark from the f
07-29-2007 21:52:49
Replacing my Kitchen sink and cabinet and have to cut out the old plumbing under sink.
It is very old and brittle.
I want to replace all shutoffs and diverter to dishwasher with new. I have copper coming from floor and would like to solder all new.
I know about taking shut-offs apart and removing delicate insides, my question is this:
Will a small torch work for heat? If so, after I flux the pieces and place together, do I apply the heat to the joint of the two pieces, or to the larger piece and let the solder draw into cracks.
Thanks for any help. Mark
KIP in MX
07-31-2007 08:19:24
 Re: Soldering Plumbing in reply to mark from the fort, 07-29-2007 21:52:49
The house I live in has all copper pipes and I bought a propane torch that hooks to old style BBQ grill LP bottle and has three different heat tips. That torch will put out way more heat than a hand held bottle torch. I clean both pieces, flux, and heat both as they go together. You should be able to tell when you get good solder flow into the joint.
dave guest
07-30-2007 20:13:07
Old plumber showed me to take a slice of fresh white bread, squeeze it in a ball and push it in the line if trickle was a problem. It breaks down later and never caused any problem.
Randy S
07-30-2007 17:50:38
To answer your question, a small torch such as a mapp gas torch or small propane bottle wont work if you cant get the water out it wont get hot enough to boil the water out you will have to use a small oxy/acctlyne torch. Put the heat on the larger fitting rather than the pipe. Ive soldered many a joint with water in them, at best its not easy, if you havent done this before then it can turn into a nightmare. Sometimes its simple and easy just drain the water and go for it then again you cant get the water out then the headache starts.
good luck
Billy NY
07-30-2007 06:52:46
For copper, one simple thing to remember, pipe has to be dry, and the surface clean where the solder is to seal a joint.
Like was mentioned, do a sample joint, clean the pieces, most fitters use the narrow sandpaper on a roll that you'll find with most plumbing supplies on the shelf, some use a wire brush etc. Coat both surfaces with flux, heat, unroll enough solder to touch the joint when it's hot enough, it will literally settle into the joint, I do as mentioned below too, say when there is a vertical riser (pipe going up) in a corner where I can't see or get to the back side of the pipe, so I touch the joint with solder while it's hot, usually just wasting material as it's already dropped into the joint, once at the right temperature, it will most likely fill the entire diameter of 1/2" 3/4" pipe. Sometimes you can fab parts of a rough in for say under a sink while it's out, then set the section, just having to tie it in, makes less joints to solder while in cramped space, do measure precise when doing this, better to leave stubs longer and cut to fit when setting, matter of preference here.
Ball valves are fine, used to be good names out there, made in U.S., Watts, Nibco, but i think it's hard to find domestic valves of quality like was had in the past. When soldering valves in, keep the heat concentrated away from the center of the valve, just a the ends of the casting, I like a little higher temperature to get it hot quick, so the solder melts and settles in, even those ball valves can succomb to heat if you are not careful, I point the flame away from the valve and heat the area where the pipe joinsthe valve. Not that long ago I did a tie in and a rough in for a bathroom I rehabbed at a customers business, and the supply pipe could not be drained down completely, did ruin 1 packing on a valve, but had to apply heat much longer, eventually the pipe dried enough, was a tough joint to set. Even with some water, and when you can't get it out, I have heated the pipe, letting it steam out an open end and dry out, before doing the joint, it's probably the only hard thing when dealing with copper, is when you can't get er drained out, or there is a slight trickle sending a drop of water to where you are working, most times you can eventually dry it with heat when one end is open, letting the steam out, just enough to set a joint, quickly apply flux and solder, other times have to go further back to where you can get the pipe dry.
Once you see the solder settle in quickly, you know the joint is good, it will leave a thin silver film just beyond the joint when you are good at it, other times you may get the occasional "stalagtite" of solder ( those things that hang down in caves LOL !) watch your feet, hands and other things for hot solder spatter.
Safety, use lots of care with an open flame, I usually take a clean water spray bottle and soak around the area I'm working, especially if wood, keep a fire extinguisher next to you and or have a helper nearby ready to use the extinguisher. Sounds ridiculous to some but it happens, my friend has done this work professionally for almost 20 years, this spring he caught a piece of asphalt coated insulation (older home) on fire and while not having gloves on he yanked out the burning piece to prevent it from catching the rest on fire, the hot asphalt dripped on top of his hand, was out for a week, happens quickly even to the best of them.
Gary from Muleshoe TX
07-30-2007 05:52:35
 SharkBite Connectors in reply to mark from the fort, 07-29-2007 21:52:49
Save yourself a lot of trouble and get you some SharkBite couplings and connectors. No soldering required and they hold just as good. I use them in the facility I manage and they have been life savers. They can be removed later if you have a problem. No need to worry about getting all the water out of existing line. Most all hardware stores carry them. You can also easily mate copper and PVC using these.
Nick R (Wi)
07-30-2007 04:42:12
Practice a little to get the feel of the process. Put some tubing in a vise and try it first. Will help a lot and give you a better looking finished fitting. Good Luck.
MarkB_MI
07-30-2007 03:17:24
Save yourself a lot of aggravation now and later by using ball-type valves. They can handle a lot more heat when you install them, plus they don't suffer from leaky packing and other problems that you get with the the older style valves. Home Depot here has "1/4 turn" Brasscraft valves that I have been very happy with.
Stan in Oly, WA
07-29-2007 22:56:46
Hi Mark,
Heat the larger fitting and let the solder be drawn into the joint. When the fitting and the pipe are hot enough to melt and draw in the solder, the solder should flow in and fill the joint completely---you don't have to touch the solder to the joint all the way around the pipe. Just to make sure, though, I usually touch the solder to the joint on the opposite side from where I am applying the heat. When it melts and draws in, it's done.
All the best, Stan
Krumholz
07-30-2007 11:05:31
 Re: Soldering Plumbing in reply to Stan in Oly, WA, 07-29-2007 22:56:46
Several things seem to have been left out but then again it may be my poor eyes. As said, heat the larger pieces until the solder is drawn into it and then _move the heat source all around the piece as the solder will follow the heat. As soon as you pull the heat away satisfied with your joint grab a thouroughy wet rag and wipe the joint in a circular motion and this will seal the solder and make it look like a real pro_____ _____
Ebbsspeed
07-31-2007 10:01:12
 Re: Soldering Plumbing in reply to Krumholz, 07-30-2007 11:05:31
I never wipe the joints, as any bit of wiggling while the solder cools from liquid to solid can cause weak joints.
