Tool Talk Discussion Forum
drill press
bruce neal
07-29-2007 11:25:57
i bought a drill press from northen tool ...not the best but should work well for my needs.it says it has a laser ... i can find it ,it has wires hooked to it ..but i dont see anything ,i hate to take it back just for that ...anyone else have this happen to them ? am i doing somthing wrong ?? thanks for the help if you can ..bruce
bruce neal
07-30-2007 14:03:22
 Re: drill press in reply to bruce neal, 07-29-2007 11:25:57
ok... i must have lost it ....i looked for over a week....every time i was in the shop and looked i couldnt find a switch for the laser...but today ..their it is,, right in front of my face....i think i am getting old...anyway thanks for the help.... i am not sure after this i should be using power tools ...ha ha thanks bruce
JOHN HARMON
07-29-2007 16:06:15
I have a Laser affair I got at Lowes for my two Power Mitre Saws. It slides on the Arbor after you put the Blade on and is powered by small Watch type Batteries,activated by the force of the blade running. My other Laser which is like a 24" Level with a laser beam built into the end of it is powered by 9 Volt Batteries. Yours quite likely has need of a 9Volt Battery and probably is activated by the travel of the Drill.Just my Idea. John
Will Herring
07-29-2007 11:32:07
I read that some of them need a 9V battery to operate the laser light, and possibly have an on/off switch. Might check and see if there's a slot for one, or if it came with a manual that says anything about it.
