Tool Talk Discussion Forum
OT: Trailer Brakes and 99 Ford F-250 SD help needed
Tim in West Pa
07-29-2007 08:32:55
Either I have my brake controller wired incorrectly or I have a bad controller. I have brake lites and turn signals on the trailer and I have brakes when I activate them manually on the controller ( a reese brakeman), but don't have any brakes when stepping on the pedal.
anybody have any suggestions?
Thanks Tim
Tim in West PA
07-29-2007 11:37:45
 Re: OT: Trailer Brakes and 99 Ford F-250 SD help needed in reply to Tim in West Pa, 07-29-2007 08:32:55
thanks for the suggestions, but I found a wiring diagram for the controller on another site. I had the green feed wire from the truck's harness hooked to the wrong wire. It's all working now.
Tim
Vapet
07-29-2007 09:48:30
Don"t have a Reese but on my electronic controller, the brake light switch activates the brakecontroller. Check that out.
big jt
07-29-2007 09:35:35
I don't know that particular brake controller.
However almost all of the current controllers have two adjusments. One for the total braking, and another for the pendulim. If the pendulim is out of adjustment you won't have any braking. Or you could have full brake when the brake lights come on.
hth
jt
KENN
07-29-2007 08:44:14
 Ford F250 and trailer brakes in reply to Tim in West Pa, 07-29-2007 08:32:55
The trailer lights and brakes come from two different fuses. Check that you have a good fuse for the brakes.
Tim in West Pa
07-29-2007 09:07:04
 Re: Ford F250 and trailer brakes in reply to KENN, 07-29-2007 08:44:14
I just went out and checked both under the dash fuses and under the hood fuses for everything that was marked trailer controller. All looks good. Do you know which numbers I should be checking? Any other suggestions?
Thanks Tim
