Tool Talk Discussion Forum
Carb magic - pickup tube self siphons
IL Kruse
07-28-2007 17:16:05
I've been pulling my hair out with a carb problem.
Oh and sorry in advance but this is a bit OT since it's for a lawnboy. Problem: Gas comes oozing out of the top of the pickup tube into the throttle when the gas is turned on.
1st, I replaced the float valve & seat and gas still came oozing out, but I could turn the carb upside down and gravity on the float made the valve seal air tight. Even though the float sure seemed fine I replaced it thinking that could be the only other problem. Gas still came out.
Trying all kinds of things, I found that if I take the pickup tube and needle out completely and leave everything else the same ... no problems ... works like it's supposed to. Leave the needle out and replace only the pickup tube? Gas comes oozing right back out again.
Any ideas?
Oh and yes I realize that without the pickup tube, the gas level has to come a bit higher, but only by about 1/8 inch. The tube that the pickup tube screws into extends well below the float level.
Thanks.
dieseldaawg
07-28-2007 21:44:35
 Re: Carb magic - pickup tube self siphons in reply to IL Kruse, 07-28-2007 17:16:05
Carb. vent is plugged. Fuel comes in past the needle, but the air is trapped and the float cannot rise, so pushes fuel out the pickup tube.
Jake
IL Kruse
07-29-2007 14:50:42
 Re: Carb magic - pickup tube self siphons in reply to dieseldaawg, 07-28-2007 21:44:35
Thanks! Makes sense and that took care of it!
scott in mi
07-28-2007 18:16:18
i know this sounds odd..... .. how is the vent in the gas cap? I jus got done repairing my cub 124s fuel system..... the kohler fuel pump on it was pumping too much pressure after 5 yr or so... i switched it back to stock gravity flow and back 2 normal. i guess what i am saying is..... an external form of pressurized fuel such as a non venting gas cap. bad primer... etc?????
IL Kruse
07-28-2007 20:23:00
 Re: Carb magic - pickup tube self siphons in reply to scott in mi, 07-28-2007 18:16:18
Well, I figure it has to be something strange ... a leak or a block somewhere.
When I had the tank on it's side, I remember gas squirting out of the vent in the cap, so I know it's not totally blocked. But that's something else to try ... just leaving the cap off and see if it changes something.
But, you mentioned the primer. I've been assuming that it's just another symptom, but it doesn't seem to push the gas out as hard. I can't find a leak though (push down on primer, put finger over hose end, release primer, works fine).
old art
07-28-2007 17:37:17
my guess is a float that is leaking and has fuel in it . take it out and put it in a can of fuel to see.
IL Kruse
07-28-2007 17:50:05
 Re: Carb magic - pickup tube self siphons in reply to old art, 07-28-2007 17:37:17
Thanks for the reply.
I think after using my head a little bit more now that I've thrown a few parts at it, I've ruled out that the new float is bad.
When I had the pickup tube out and everything hooked back up, I turned off the fuel and disconnected the fuel line to the carb. I hooked up a vinyl tube and tried to blow into the carb past the valve. I couldn't get a bubble through, so it seems like it did it's job.
