Tool Talk Discussion Forum
when or did they convert to a 60hz service at your house/far
buickanddeere
07-28-2007 09:55:35
Did anybody here ever have anything to do with or have any stories. About the change over from 16-2/3,25,40 or 50 cycle power. To the 60hz of today?
CRUSADER
07-30-2007 18:33:25
 Re: when or did they convert to a 60hz service at your house in reply to buickanddeere, 07-28-2007 09:55:35
In Europe they use 50 Hz. Traveling and being stationed over there can come up with some humourous stories. LOL, a guy I knew bought a washer/dryer set at a yard sale that the people had and brought back with them from England. It was a full size top loader and was 220 volt 50 hertz. He hooked them up and that's when he realized that he oops'd. His settings didn't work right, but sure would wash a load of clothes. But the dryer running on 60 hertz spun the turned it WAY too fast and would get hot but the clothes would be wet. Also have to be careful with dual-voltage appliances and electronics.
Jim
ohio
07-28-2007 21:41:34
the house i grew up in had provisions for a delco system (dc). one of edisons brainfarts. he was a proponent of d.c., the archnemisis to the brilliant nicola tesla, if you will. don't get me wrong, d.c. has it's uses, but it loses much in the transmission, and therefore must be generated or rectified on site. also, wire sizes are considerably upsized if low voltage d.c. is used.
turned out nobody realy wanted a gas engine inccesantly sputtering away, and 4/0 wire strung about the place!
MarkB_MI
07-29-2007 00:39:08
 Re: when or did they convert to a 60hz service at your house in reply to ohio, 07-28-2007 21:41:34
"d.c. has it's uses, but it loses much in the transmission"
OH, you might be surprised to learn that DC has been used for many years for long distance power transmission. The losses are actually lower with high voltage DC than they would be for AC at the same voltage. The downside is the cost to convert ac to dc and back to ac, which is why DC is only used over long distances (several hundred miles).
Gerald J.
07-28-2007 13:46:08
I had a few minutes and put google to work. The references reminded me that the book I had was by B.G. Lamme and included his article on the selections of power frequencies.
Gerald j.
Red Dave
07-28-2007 15:59:11
 Re: when or did they convert to a 60hz service at your house in reply to Gerald J., 07-28-2007 13:46:08
That article is very good, but it was apparently written a couple of years ago. Seems that the advantage of the flywheel effect of rotating masses of iron had been seriously underestimated.
The old rotating freq at Safe Harbor has recently been given a new lease on life. Not sure, but I think that Metuchen is already gone though.
Gerald J.
07-28-2007 21:17:48
 Re: when or did they convert to a 60hz service at your house in reply to Red Dave, 07-28-2007 15:59:11
Oh, I don't think that flywheel effect has been at all understimated. It was always quite present when starting the rotary converter. Today the solid state converters depend a lot on their low impedance and the stiffness of a substantial power line supplying them to effectively supply that flywheel effect and to be able to modify that flywheel effect if need be to make for softer starts of load devices or to limit fault current.
A lot of power systems, especially those in urban settings often have 100 times the short circuit current (and hence really low source impedance) than they had 25 or 30 years ago. Which leads to 100K amp fault currents in 240 volt panels which means the panel has to be made a whole lot sturdier than the old 15K amp fault current main panels.
Any article is dated by the time its converted from notes to print or the internet and power systems are always changing whether the owners want to or not.
Likely the scrap prices for the copper and iron of the trashed rotary converter almost paid for the solid state converter which gives higher efficiency and easier repair.
Gerald J.
Red Dave
07-29-2007 09:29:08
 Re: when or did they convert to a 60hz service at your house in reply to Gerald J., 07-28-2007 21:17:48
Maybe in theory, but here where we actually operate the 25 hz equipment, it hasn't worked in practice. Amtrak wants the rotating iron on to stabilize their system.
But that is a good thing because it helps me make a living.
Gerald J.
07-29-2007 10:20:05
 Re: when or did they convert to a 60hz service at your house in reply to Red Dave, 07-29-2007 09:29:08
That would hint that the power system feeding the solid state converters isn't all that stiff and probably that the controls don't make the solid state converters as bi directional as the synchronous rotary converters to absorb dynamic braking back feeds.
I'd not be really surprised if some of the solid state converters weren't bidirectional as the power company hasn't been a fan of customers pushing power back into the system because the power plant controls aren't always adapted to that and such back feeds make the power system unstable (flashing and blinking lights).
Gerald J.
Red Dave
07-29-2007 11:43:41
 Re: when or did they convert to a 60hz service at your house in reply to Gerald J., 07-29-2007 10:20:05
It's really more a function of the small size of the 25 hz system. Doesn't take much to upset it compared to the huge 60 hz system. A couple hundred megawatts at most vs 10's of thousands of megs just in our part of the country on the 60 hz side.
I don't know if the static converters can go to 60 or not. I doubt that they would want them too, at least not for very long. It would be uneconomical most of the time. And static converters can't seem to handle much reactive load either, which is no problem for the old rotating equipment. We are on a lot for voltage support.
jimont
07-28-2007 13:42:28
Here in Ontario, the change came right around 1955. I was still in public school (one room grades 1-8, one teacher).
NEsota
07-28-2007 13:16:09
RADIO AS I KNOW IT
The earliest radio signals were generated by a �spark transmitter�. This was a mechanical generator connected to an antenna. The connection between the two was made and broken to correspond to a pattern of dots and dashes, Morris Code. This is what the Titanic used. As electronics became more sophisticated, amplitude modulation, (A.M.) was introduced and the RF amplitude was varied to correspond to the audio range. The first commercial radio broadcast in the U.S. started about 1920.
The most common �house� radio of the late 40�s and 50�s was the AC/DC superhetrodine. It would operate on either power source but you might need to turn the plug connection over on DC to get the polarity right so that the current would flow from the ELEMENT to the PLATE in the tubes. Superhetrodine, meant that the received RF was mixed with an internally generated RF signal so that a differential signal, (usually 455KC) was generated. There were two or more stages of frequency tuned amplifiers to boost this signal, only then was the audio detection done and amplified for the speaker.
Where solid-state amplifiers are primarily current boosters, the tube-type amplification was a voltage device and would not boost power at the 6 or 12 volts provided by car electrical systems, they had a �vibrator� that chopped that low voltage into a square wave of a frequency high enough to feed the primary of a voltage step-up transformer which was filtered at the seconary and provided to the PLATES of the amplifier tubes at a DC voltage that could range in the low hundreds.
SMALL 60 CYCLE VARIANCE
I was a municipal power plant operator at a small town diesel-electric plant, 800KWH maximum. There was no electronic reference to keep the plant running at 60 cycles. I am not sure if there were even mechanical governors, the plants frequency output varied as the load went up and down. Anyway if the operator was sloppy the electric clocks could gain or loose several minuets during an eight hour shift. Eventually an operator would speed up or slow down the frequency to get the clocks on the system back on time. I am sure that the output of the plant was often 1� to 2 cycles, plus or minus 60. The phone would have been ringing if television was affected and the phone did not ring. This was in the mid 1960�s. My impression was the some early TVs referenced the power signal but later generated there own synchronous signal.
Gerald J.
07-28-2007 10:10:38
I wasn't here when it happend, but customers of the Ft. Dodge Des Moines and Southern RR would have changed in 1955 when the RR power plant at Fraser, IA was flooded by high water. It never ran again. It was still there about 1970 but all the copper had been stripped. The line ran on diesel power a short time, then sold to the CNW. Now the track that remains from Boone through Fraser to Wolf belongs to the Boone and Scenic Valley who run steam, diesel, and have electric wire on part of it again.
Southern California changed, but I'm not sure when.
Gerald J.
crisco(IA)
07-28-2007 11:07:25
 Re: when or did they convert to a 60hz service at your house in reply to Gerald J., 07-28-2007 10:10:38
Gerald, I"m certain that was Direct Current, so there wouldn"t have been HZ involved with regards to the railroad. I know it was 60 HZ in the early 30"s as my mom had a clock that you started by spinning the armature on the back of it to make it run.If the power failed, it stopped at the exact time and needed to be restarted manually. I"d also think that radios would be affected by a variance in cycles(remember oscillators in the old car radios?)
Gerald J.
07-28-2007 12:46:50
 Re: when or did they convert to a 60hz service at your house in reply to crisco(IA), 07-28-2007 11:07:25
The Ft. Dodge and southern was 25 Hz. Radios with 25 Hz power transformers show up in Boone antique shops on occasion. That line was too long to run on DC. The trolley on the Boone & Scenic Valley is DC. But its all new stuff.
Transformers are designed for a minimum frequency and give the same performance up to a few KHz though the core loss changes with frequency. At the low end the core loss falls as the induduced magnetic field falls due to the higher reactance of the windings, but at higher frequencies, the core loss rises because of edy currents in the core laminations.
So a 25 Hz transformer works fine on 60 Hz and even higher and so does the radio. I've designed transformers so I know how they work.
25 Hz and lower frequencies work better on the series traction motors, less sparking at the brushes.
There were many clocks that weren't self starting, a very simple synchronous motor was used. And it would run equally well backwards. A bit of shading on the pole pieces (copper band around part of the pole) will make them start in the right direction, but even then some timer motors I've had apart have a pall that catches in the gears if the motor starts backwards and the bounce off that gets them running fowards. Synchronous motors are very sensitive to power frequency and such clocks make a good test instrument for setting the portable generator.
Gerald J.
John in Nebraska
07-28-2007 10:12:57
When television became popular in the early 50s, it was found that the screen would roll if the cycles were not the same. Is when the television manufacturers got to gether to get the power companies to standardize. Was told this by an elderly tv repairman.
Gerald J.
07-28-2007 11:02:09
 Re: when or did they convert to a 60hz service at your house in reply to John in Nebraska, 07-28-2007 10:12:57
But when color came along the vertical frequency became closer controlled, tied precisely to the color burst frequency (3.579 MHz), and horizontal sweep frequeny and shifted to 59.93 something. Never precisely 60 Hz. And better TV circuits didn't have that roll problem. The ratios of those three frequencies have to be held precisely or the color information won't mix in with the video information (where it costs half the TV resolution).
Gerald J.
