Tool Talk Discussion Forum
JB Weld Plastic Radiator Tank...?
Glenn FitzGeral
07-23-2007 20:14:10
The saga continues....Near as I can tell, the temperature sensor on my son's '95 Saturn is bad resulting in the undependable electric cooling fan. We have not yet registered/licensed it so a trip to Auto Zone for a free computer scan is not an option. I just bought a new sensor ($10) part. The relay is fine. Now on to the next problem....One of the radiator tanks has a 2" vertical crack in it which likely resulted from overheating.
Have any of you successfully JB Welded a plastic radiator tank? The radiator shop wants $70 to put on a new tank, and the salvage yard wants $60 for a used one.
Also, this radiator does not have a cap? Is there a pressure release somewhere in the system?
Thank you, Glenn F.
Glenn F.
07-24-2007 09:47:47
 Re: JB Weld Plastic Radiator Tank...? in reply to Glenn FitzGerald, 07-23-2007 20:14:10
I got on the phone this morning and called every salvage yard in the phone book (37 of them). I found a radiator for $50, and it's only about 8-10 miles from here. I'm going to pick it up now.
Thank you to each of you who so carefully and thoughtfully respond to my questions. I need you folks.
Glenn FitzGerald
Bob
07-24-2007 09:55:52
 Re: JB Weld Plastic Radiator Tank...? in reply to Glenn F., 07-24-2007 09:47:47
Smart move to replace it. Better than a failure on the highway, and even a "blown" engine, if the driver doesn't pay attention to the gauges/lights.
Shawnspeed3
07-24-2007 09:07:33
Glen, get the tank replaced, not only is glycol hard to remove , most plastics have a release agent in them that makes them extremly hard to "glue" with epoxy. the only sure bonds are solvent welds where the solvent melts the base material with a patch over it. also the sonic welding of plastic also works , but is more production intent that repair minded. Some people have no trouble with JB weld in similar instances,but I am not one of them. your Radiator cap in thet car should be on the overflow bottle , as I belive that they are a pressurized overflow bottle,( you can tell if it is a pressurized bottle by the internal gusseting, or egg create inside the bottle) be careful and don't open it hot. If it is not on the bottle , it could be on the thermostst housing. good luck Shawn
Gumby
07-24-2007 08:44:09
If possible, depending on the location, why not try a small amount of fiberglass patch with plenty of resin. That stuff gets just as hard as Bondo or JB Weld and will span the crack with plenty of lateral tensile strength.
Hal/WA
07-23-2007 21:47:18
I repaired a crack in a Mazda Protege upper radiator tank with a 2-part kit marketed for that purpose. I thought it was epoxy, but it might have been something else. The repair held for about a year, but then started leaking again.
I drained the coolant down to below the crack a ways and then cleaned the area very carefully with carb cleaner and then lacquer thinner. After it was dry I roughed up the bonding area with coarse sandpaper. I applied the mixed goo with a popsickle stick with the radiator still in the Mazda. The goo set up in about 15 or 20 minutes and I refilled the radiator 24 hours later. It held pressure for a year. If I had it to do over, I think I would have added a metal patch over the epoxy, or even epoxied the popsickle stick over the crack, since it looked to me like the repair flexed where it had previously cracked.
You wouldn't be out much trying to repair the tank, especially if the car doesn't have to be used right away anyway. You might want to check out your auto parts store for the specific kit--it might be something different than JBWeld that might work better. And then it might not work well at all, depending on the tank material and the location and nature of the crack.
I usually try repairing something first and if that doesn't work out, I replace what broke or wore out. Good luck!
rockyhawaii
07-23-2007 21:44:38
I have repaired two radiator tanks with JB, but use the one made for plastic. Both of the repaired tanks have been working fine for around two years, at least.
Steve Crum
07-23-2007 21:06:24
I wouldn't advise it. The inlet side tank in my Eldorado cracked a couple years ago. I took Chet's advice (from Custom Rebuilders) and had them replace the tank (with guarantee). Quite a job getting the radiator out of that car. Chet gave me the old tank and I did some experimenting with different epoxies, each one cracked or did not bond well enough. 80 bucks for a new tank was money well spent. Especially since #1 daughter drives this most of the time nowdays.
Gary from Muleshoe
07-23-2007 20:18:54
I have never used JB Weld but I have used a two-part epoxy on a simular problem acouple years back and it is still holding.
